What is this part called?
Old Jul 27, 2008 | 06:36 AM
srburk's Avatar
Default What is this part called?
I was replacing the air filter and noticed that this part was cracked.
What is it called? It looks VERY SIMPLE to replace. Am I wrong? To me, it looks as though I just order a new part, unscrew the cracked one and take it our. Reverse to replace with the new one.
Should I get a Honda part or would any part be ok? Anything I'm missing?
Thanks!
Scott
Old Jul 27, 2008 | 08:18 AM
Hawkze_2.3's Avatar
Default Re: What is this part called? (srburk)
Just an intake pipe or intake tube... I'd look on eBay for a cheap used one or get one of those $30 intakes and just replace that rubber section with the metal tube from the intake.
Old Jul 27, 2008 | 08:43 AM
TheMuffinMan's Avatar
He knows where you live!
^^ boingo
I'd either hit up a junkyard if you want to keep it stock or get a cheap SRI from Ebay
Old Jul 27, 2008 | 11:32 AM
radiuslight's Avatar
Default Re: (TheMuffinMan)
Hmmm.....
hitting up the junkyard for just that part is not worth it!
1. you probably wont find it!
2. ur gonna have to look around and spend money on each entrance
3. if you do find one It will last you a year maybe.......cause its used!
If you wanna be ghetto just use duct tape....it will work just fine! not something I recommend but it works 100%
if you wanna spend money just buy it new!
autozone pepboys kragen napa one of those should have it...call them up and compare prices!
Modified by radiuslight at 5:22 PM 7/27/2008
Old Jul 27, 2008 | 02:15 PM
Default Re: (radiuslight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by radiuslight &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm.....
If you wanna be ghetto just use duct tape....it will work just find! not something I recommend but it works 100%
autozone pepboys kragen napa one of those should have it...call them up and compare prices!</TD></TR></TABLE>
What junkyards do you go to?
Mine = $1 to get in, that part - $5 max
Old Jul 27, 2008 | 02:40 PM
all the ones in Los Angeles!
u-pick-parts and others
Its probably different out there!
here in LA there is big demand for accord parts
I always find accord stripped to the bone!
entrance runs about $2-5 bucks
Old Jul 27, 2008 | 02:41 PM
Thats cool !
I wish it was like that here! Here min for a part it will be $15-20
Old Jul 27, 2008 | 02:48 PM
boostedh23's Avatar
go to a junkyard or buy the pipe from someone who has replaced it with a new intake
Old Jul 27, 2008 | 05:34 PM
mavvrik's Avatar
You basiclly have three options:
1) If you really want to stick with stock, you can go to your local dealership and order the intake tubing from them.
2) Visit your local Autozone, Advanced, Checker, etc.. and buy a cheap replacment for roughly 30-40 dollars.
3) You can use your local junkyard, ebay, craigslist, etc... to find a used one.
Old Jul 27, 2008 | 07:45 PM
srburk's Avatar
Thanks to all for your help. I found it online with Majestic Honda http://www.hondaautomotiveparts.com for $22.57.
Now, another question. Easy fix? It looks easy.
Do I need to replace any of the connectors that are attached? They look fine.
Old Jul 27, 2008 | 07:55 PM
Nope it's simple.
2 of those spring things and then swap it out and put the new one in.
Old Jul 27, 2008 | 08:49 PM
mavvrik's Avatar
Yeah, the stock flanges are supplied for you with purchase
Old Aug 5, 2008 | 11:40 AM
srburk's Avatar
Thanks everybody for your help. Part came in this afternoon (during a tropical storm even) and I had it replaced in less than 30 minutes.
mwaedow
Feb 15, 2010 12:57 PM
kartman5
Honda Civic (2006 - 2015)
Feb 16, 2009 01:46 PM
pjr710
22
May 23, 2007 04:53 AM
CRAZYEG9
May 2, 2005 01:09 AM
jaycapz
11
Sep 29, 2004 10:05 AM
