Carbon Fiber
Old Jul 26, 2008 | 11:04 PM
paniaguae640's Avatar
Default Carbon Fiber
I have a 94 honda prelude si and I wanted to know what is the weight distribution on the car stock. And also if Seibon or VIS has TRUE carbon fiber hoods and trunks.
Old Jul 27, 2008 | 08:13 AM
Hawkze_2.3's Avatar
Default Re: Carbon Fiber (paniaguae640)
Stock weight distribution is somewhere around 65% front 35% rear.
All the VIS stuff I have seen is fiberglass with a CF layer on top. I have a hood and trunk and they are both like that. Seibon might offer something like that, but probably not for Preludes.
Old Jul 27, 2008 | 08:24 AM
G2IntegraGS's Avatar
Default Re: Carbon Fiber (Hawkze_2.3)
My seibon hood is a plastice base/frame and CF on top. Its super light.
Old Jul 27, 2008 | 08:41 AM
do i have this right? the closer you are to 50/50 weight distribution the better the car will handle because of the center of gravity rule. so its better if i just get a carbon fiber hood and move the battery to the trunk? and dont do anything to the trunk. what is the preludes stock weight? does that include the spare tire in the trunk?
Old Jul 27, 2008 | 03:22 PM
Hawkze_2.3's Avatar
Default Re: (paniaguae640)
A stock 4th gen weighs around 2800-2900, S model being the lightest up to the VTEC model being the heaviest.
Old Jul 27, 2008 | 04:11 PM
Kronn 98SH's Avatar
ok....
94 Si = 2866 for MT and 2921 for AT....if you're a guy and you care about your ride, we'll assume you have the MT. a car battery weighs ~50lbs and a CF hood reduces by (guessing) ~30lbs....now assuming Hawkze's info is correct (no reason to assume it isn't), you would be removing 80lbs from the front and adding 50lbs to the rear....that would change your vehicle from 65%F/35%R to about 63.75%F/36.25%R....negligable in my opinion
By the way, if you're a girl and have the automatic, the % difference is less. Closer to 64%F/36%R
Old Jul 27, 2008 | 06:09 PM
Hawkze_2.3's Avatar
Default Re: (Kronn 98SH)
For what it's worth, I weighed my car in the beginning of '05 and I came up with 1560 lbs on the front axle and 960 lbs on the rear axle. Of course that is a bunch of weight reduction all around, but the rear is still a good bit lighter than the front.
This was a truck scale, so who knows how they are set up, but it's all I have
Old Jul 27, 2008 | 08:35 PM
Default Re: (Hawkze_2.3)
im a guy and it is MT...... Hawkze just wondering what things did you remove to reduce the weight and get it that close to 50/50?
Old Jul 27, 2008 | 08:43 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paniaguae640 &raquo;</TD></TR><TR><TD CLASS="quote">im a guy and it is MT...... Hawkze just wondering what things did you remove to reduce the weight and get it that close to 50/50?</TD></TR></TABLE>
It's actually not very close to 50/50...it's still around 65/35.
I've done all kinds of stuff to reduce weight, if you like, I can IM you the list
Old Jul 27, 2008 | 09:15 PM
Kronn 98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">It's actually not very close to 50/50...it's still around 65/35.
by your numbers, it's 62/38
Old Jul 27, 2008 | 09:32 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kronn 98SH &raquo;</TD></TR><TR><TD CLASS="quote">
by your numbers, it's 62/38</TD></TR></TABLE>
Yeah, close enough A LOT has changed since that weigh in, I really wonder where it's at now.....
I know the front has lost more weight than the back.
Old Jul 28, 2008 | 09:56 AM
I've done all kinds of stuff to reduce weight, if you like, I can IM you the list </TD></TR></TABLE>
send me an email at paniaguae640@hotmail.com
Old Jul 28, 2008 | 11:07 AM
Hawkze_2.3's Avatar
send me an email at paniaguae640@hotmail.com</TD></TR></TABLE>
Will do.
Old Jul 28, 2008 | 02:36 PM
Scheizty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paniaguae640 &raquo;</TD></TR><TR><TD CLASS="quote">do i have this right? the closer you are to 50/50 weight distribution the better the car will handle because of the center of gravity rule. so its better if i just get a carbon fiber hood and move the battery to the trunk? and dont do anything to the trunk. what is the preludes stock weight? does that include the spare tire in the trunk?</TD></TR></TABLE>
The farther back that you move the battery, the better results you get. Also, pulling the spare out is causing you to increase the distribution to the front.
A good way to move weight distribution AND decrease understeer is to get a softer, lighter front sway bar (or remove it altogether) and get a stiffer rear sway bar. Since this causes the rear to sway less than the front, you will be increasing traction in the rear wheels.
Old Jul 28, 2008 | 02:53 PM
E-Money's Avatar
Default Re: (Scheizty)
whos says this is gonna help your car "handle better" if the prelude was designed to be a good handling car at 65/35... lets face it your not making a track car... buy the struts, springs and swaybars
Old Jul 29, 2008 | 07:47 AM
Scheizty's Avatar
Default Re: (E-Money)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Money &raquo;</TD></TR><TR><TD CLASS="quote">whos says this is gonna help your car "handle better" if the prelude was designed to be a good handling car at 65/35... lets face it your not making a track car... buy the struts, springs and swaybars </TD></TR></TABLE>
Maybe YOU aren't.
B19CivicHB
Oct 17, 2017 11:35 AM
HKCivic
12
Sep 5, 2008 08:45 PM
B bOy CrAyOn
19
Aug 26, 2005 08:42 PM
ddua
Aug 21, 2003 08:52 AM
