replaced head gasket.... white smoke from exhaust, breather tube and dipstick/turbo area still after
Old Jul 26, 2008 | 01:59 PM
teggy teg's Avatar
Default replaced head gasket.... white smoke from exhaust, breather tube and dipstick/turbo area still after
car was blowing whiteish smoke from the exhaust and breather tube... oil changed showed coolant within. i figured a blown HG. So, i replaced the head gasket. the head wasnt warped, check out within the .002 limits with a dial indicator. using arp studs, torqued correctly
now, its still smoking from the exhaust and breather tube but now also near the dipstick/turbo manifold to turbo connection area. i first blamed the smoke from their on excessive oil spillage from pulling the head while doing the HG install... but now im not sure.
ive only driven about 5 miles tops, and has run for about 20-30 min total between a few start ups and checking things out. runs and sounds fine. seems good, but it felt good before the head gasket install as well.
side notes. i do have a block guard... which sits slightly below the deck surface. I washed the rings about 5000 miles ago so, i pulled the head and replaced the rings as well as a new HG.
i didnt notice any excess oil in the exhaust ports when i pulled the head, spark plugs were dry as well. My TB had a buildup of dark "soot" but nothing wet.
My guess is that the next step would be a leakdown test, but i was wondering if maybe my turbo seals were bad too?
any thoughts?
Old Jul 26, 2008 | 07:37 PM
97grnrs's Avatar
Default Re: replaced head gasket.... white smoke from exhaust, breather tube and dipstick/turbo area still a
thats usually sign of ring land crack or bad rings etc...
Old Jul 26, 2008 | 09:33 PM
b16bri's Avatar
Well smoke out of your breather is a sing of cracked ringlands or warn rings it's caused by all the blow by you now have. But I'm not sure if the smoke would be white in color... I would say do a compression and leakdown test for sure and let me no what results you got. could be a little bit of sleeve damage.
Old Jul 26, 2008 | 11:25 PM
ITR.#1446's Avatar
do a leak down and compression test i just had the same symptoms and 3 pistons had cracked ringlands but only one cylinder showed low compression and 45% on the leakdown.
Hiboost 2.0
Aug 12, 2011 03:37 PM
2001tegy
Sep 12, 2009 01:00 PM
EfpormantypR
May 6, 2009 03:27 PM
andyvaj
11
Sep 18, 2008 11:16 PM
CBlockDis
Jul 16, 2005 11:55 AM
