what does this cel code mean?
okay i have a 93 civic hatch cx with a d15b8 motor and a d15z1 head. i have a cel code and when i jumper it to check the code it just keeps doing long 1 second blinks over and over and over and never ends the sequence. and also on my model i have the green up shift arrow light in the cluster to help u save fuel but my light isint working now neither
https://honda-tech.com/zerothread/1901557
so as you can see it can blink for while you just have to count
holy compression ratio batman. comes out to aprox 12.5:1.
hopefully you're seriously highly tuned with that setup.
CEL 10, make sure you're IAT is plugged in, and the IAT and EVAP purge are not switched. (common for head/engine swaps)
yeah its supose to be a high comp motor but its not tuned i got the stock ecu the vtec isint hooked up and i need a adjustable cam gear.
right now its actually one big pos because i cant get the thing to stop smoking , now its throwing a cel code and i get about 200 miles on a tank of gas which isint right and its slow as freak in my opinion and bogs down when going up hill.. but i payed 500$ for a 93 cx hatch with a clean title and a straight body i cant complain to mch
and if it is ended a code 10 then isint it supose to have a longer blink indicating that it is starting the code over again? all of the blinks are the same i used a stop watch even and got to over 300 when i stoped counting
CEL 10 will be a single one second flash, then a 1.5-2 second space then another single one second flash. (repeats until the battery runs out)
the 1.5-2 second pause is how it tells you that it's starting another code, or in this case restating the first code.
If it will help I can take a quick video of what CEL 10 looks like.
BTW, it bogs and runs like crap because you have a low flow high fuel eficient head coupled with a minimal dish piston, which yeilds high compression. PLUS you're running on the CX ECU, which is designed for a very different head design, and a lot less compression. At this point I'd be glad you have CEL 10, it'll richen things up so you don't kill your engine.
Also that head will never flow right to produce decent power. Especially pre-VTEC.
You'd be much much better off with a Z6 head.
Modified by Relic1 at 10:35 PM 7/26/2008
if u could get a video of it i would apreciate it because all my flashes are about 1.5 seconds long i can say 1 1000 and 1 very slowly and it still takes longer . i was gonna take a video of it but my dog ate the camera lol..no really i swear she did she even tried to eat a spark plug once
and yes i plan on just getting an entire d16z6 very soon as i want to build it for boost.
i think all the problems i have are head and block combo related. im gonna try to sell or trade my engine for a d16z6
didn't forget about this...
Vid of CEL 10, on my daily driver. (93 EX)
right click, save as. ~3Meg (tried to compress further but it got crappy)
http://www.b18c5eg.com/images/CEL10.AVI
