Fill hole for 98 prelude tranny
Old Jul 26, 2008 | 07:58 AM
2ndchirp's Avatar
Default Fill hole for 98 prelude tranny
Hi i am doing some work on a 98prelude and i wanted to kno where do i put the trans fluid ..its a 5speed h22... i took the old axles out and alot of fluid came out the right side and i cant find where to put the fluid in to.
Old Jul 26, 2008 | 08:04 AM
hu's Avatar
hu
Default Re: Fill hole for 98 prelude tranny (2ndchirp)
The fill hole should be above the drain drain hole. I forget what size socket you need to remove the bolt.
Old Jul 26, 2008 | 08:25 AM
2ndchirp's Avatar
Default Re: Fill hole for 98 prelude tranny (hu)
is the drain hole the 17mm bolt? is the fill hole smaller?
Old Jul 26, 2008 | 09:26 AM
hu's Avatar
hu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndchirp &raquo;</TD></TR><TR><TD CLASS="quote">is the drain hole the 17mm bolt? is the fill hole smaller?</TD></TR></TABLE>
17mm sounds right. In fact 17mm is right.
Old Jul 26, 2008 | 10:30 AM
honda3431's Avatar
fill it from the vss, you can get more in that way.
Old Jul 26, 2008 | 05:48 PM
2ndchirp's Avatar
Default Re: Fill hole for 98 prelude tranny (honda3431)
vehicle speed sensor??
Old Jul 26, 2008 | 07:07 PM
honda3431's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndchirp &raquo;</TD></TR><TR><TD CLASS="quote">vehicle speed sensor??</TD></TR></TABLE>
you have to take it out of course. fill the fluid through that hole until its full.
Old Jul 27, 2008 | 11:38 AM
2ndchirp's Avatar
OKK.. THANKS FOR THE HELP!!!
Old Jul 27, 2008 | 07:46 PM
Chris F's Avatar
Make sure you put the right amount in.
Also, there's a vent on top that is perfect for a royal purple MTF fluid bottle tip. You can just squeeze it in there, no bolts.
-Chris
i-VTEC_DOHC
Honda Civic (2001 - 2005)
May 31, 2012 03:48 PM
Damon Reeves
Apr 15, 2007 09:11 AM
B16b-EJ8
Sep 11, 2006 02:17 PM
xd69
Jul 16, 2005 05:44 PM
Edwardo911
30
Sep 10, 2004 01:43 PM
