knock sensor location
Old Jul 26, 2008 | 07:28 AM
davidu's Avatar
Default knock sensor location
hello, i am trying to replace my knock sensor. i had it checked by someone who knows what they are doing ( i think) and i was told it had gone bad. with that in mind i bought a new one and went to it this morning to replace it. now here is the catch. i think i know where it is on the car. and if im right i bought the wrong one at advance. but just to be sure i wanted to ask.
so is the knock sensor on a jdm obdo b16 located next to the oil filter? kind of behind the alternator? if so i have to run back to advance, if not i have to run back outside. it has one wire and a rubber boot covering the connector and the whole head of the sensor. if it isnt the knock, what is it?
Old Jul 26, 2008 | 07:42 AM
crx_si-r's Avatar
Default Re: knock sensor location (davidu)
to locate it look at your intake manifold. there should be a spot right in the middle of the manifold where it connects to the block. you should see a 12mm bolt that holds the manifold on, its right below that. pretty much in the middle of the block almost where the head/block meet.
Old Jul 26, 2008 | 08:08 AM
davidu's Avatar
Default Re: knock sensor location (crx_si-r)
ok i am trying to look there, but i see no sensor.
this is what i do see and what im trying to desrcibe
the lower sensor has the wire removed and i thought that was the knock sensor. it is to the left of the oil filter you see in the picture
Old Jul 26, 2008 | 10:22 AM
Zaakro's Avatar
that is the knock sensor
Old Jul 26, 2008 | 10:30 AM
davidu's Avatar
Default Re: knock sensor location (Zaakro)
thats a mixed blessing, now i just have to find one
thank you for your help
Old Jul 26, 2008 | 10:43 AM
93excivic's Avatar
im guessing that you have a b16, well it located under the intake manifold and behind the block and on top of the oil filter but its about 1 to 2 inch below the intake manifold. the ine that is in the pix os the oil pressure sensor.
Old Jul 26, 2008 | 02:01 PM
crx_si-r's Avatar
Default Re: knock sensor location (93excivic)
yea the knock sensor should plug right in. should be square type of end for the plug too.
Old Jul 26, 2008 | 04:50 PM
Bite_Size's Avatar
ok but how would he find a knock sensor for an obd 0 motor thats JDM. i would have never thought they would sell that at advance or autozone. i'm just tryin to chime in and learn so excuse my $.02
Old Jul 26, 2008 | 06:39 PM
gearhead16's Avatar
Default Re: (Bite_Size)
look up higher you may have to pull off ur oil filter to see it but the pic shows the oil pressure switch.
Old Jul 26, 2008 | 11:55 PM
crx_si-r's Avatar
Default Re: (gearhead16)
as far as i know a knock sensor from a obd1 b16 should work. i know it worked in my obd0 LS/V
Old Jul 27, 2008 | 11:01 AM
Zaakro's Avatar
Default Re: (crx_si-r)
yeah you are right that is the oil pressure switch
Corksil
27
Jul 14, 2011 06:10 PM
92'si
Feb 8, 2010 06:27 PM
nighttrain33
May 28, 2009 10:26 PM
98civic94gsr
Jan 20, 2005 04:17 PM
MrFatBooty
Dec 12, 2001 10:11 AM
