Question About my possible paint job
I have a couple of questions.
First i want to let you know what ima do, I want to paint it my self but i want to use like a primer or Those shinny primers and i am going to have my friend tag on both sides of my car and this is were the questions come in. Btw ill be using Krylon
1st What kinda of primer/good paint i should get or additive so the kryoln can adhear to the paint.
and what can i use to make it last like a clear or something.Thanks
if you want to use a primer you should stick with a sprayable 2k urethane primer. I reccomend dupont or ppg, they are urethane and chemically activated and cured. And if your trying to spray paint on top of it you can, but unless you have a spray can that you can add an adhesive agent in than you are out of luck. As far as laying clearcoat, your out of luck on that one as well. If you lay real clearcoat than your going to have to sand your primer and clean it. First youll have to deal with trying to lay clearcoat over sanded primer, good luck with that one, that primer will absorb the clear like a sponge, Primer needs sealer or basecoat over it or it tends to have problems. Second youll have to deal with the cleaner agent. If your using the correct stuff that you should use than itll strip that spray paint right off. If it doesnt, as soon as the clearcoat touches that spray paint, be prepared for some bubbly action. The activators and agents in the clearcoat do not react well with aerosol spray paint. You may be able to use some other type of clear enamel spray paint or something like that. but thats getting kinda ghetto if you ask me. but i am also totally against these people doing roll on paintjobs with marine paint. but its there car and business.
Thanks bro but i just got a goood deal on Type R NHBP so ima spray it with that now i just made another thread on how hard it is to spray!
