new built motor problems.....
Old Jul 25, 2008 | 07:25 PM
HondaKid_1's Avatar
Default new built motor problems.....
hey guys i just did a full rebuild on my 96 gsr and for some reason when the motor heats up something is ticking really loud. it sounds like valves. but do they get louder as the motor warms up? or is it something eles? i know its in the head. do i need a valve adjustment? the head was milled and hot tanked. make a diff?
Old Jul 25, 2008 | 08:37 PM
HondaKid_1's Avatar
Default Re: new built motor problems..... (HondaKid_1)
bump
Old Jul 25, 2008 | 09:05 PM
vtecb18c's Avatar
is there anyway you can post a vid on youtube for us to hear the noise...for all i know it could be an injector pulse
Old Jul 25, 2008 | 10:18 PM
HondaKid_1's Avatar
Default Re: new built motor problems..... (vtecb18c)
would a injector pulse only get loud when it warms up? cause cold it sounds fine its when it warms up. its all stock. :/
Old Jul 26, 2008 | 12:33 AM
TOO MUCH TORQUE's Avatar
probably your valves weren't adjusted properly. when engine heats up, the metal expands which is probably causing the tapping, valve clearances are out of spec is my guess.
Old Jul 26, 2008 | 09:17 AM
Boostin_GSR's Avatar
Default Re: (TOO MUCH TORQUE)
An upgraded valvetrain has been known to make alot more noise from the head as well.
Old Jul 26, 2008 | 11:43 AM
HondaKid_1's Avatar
Default Re: (Boostin_GSR)
stock cams and skunk2 valve springs, stock valves yeah the only thing that is upgraded is the valve springs. oh well doing a valve adjustment right now see how it goes.
Old Jul 26, 2008 | 12:40 PM
jdm inc's Avatar
Default Re: (HondaKid_1)
try doing a valve adjustment
Old Jul 26, 2008 | 12:42 PM
HondaKid_1's Avatar
Default Re: (jdm inc)
just did one. most were to tight. would that cause loud valves? none were loose. :/
Old Jul 27, 2008 | 10:00 PM
HondaKid_1's Avatar
sorry for the video quality but there is a vid. of the ticking. its only there when you are at idle. when i first start it its not there. when it starts ticking i rev it it goes away.
http://www.youtube.com/watch?v=cI4SYsN1to0
Old Jul 27, 2008 | 10:17 PM
vtecb18c's Avatar
the only reason i say injector pulse is because it goes away completly when you touch the throttle...but the thing that gets me is you dont hear it when you first start it? you got me man
Old Jul 28, 2008 | 12:17 AM
HondaKid_1's Avatar
Default Re: (vtecb18c)
i got myself im confused and pissed cause i dont wanna drive it and i have been without a car for like 2 months. sucky need to figure it out tho.
Old Jul 28, 2008 | 01:17 AM
slowtegkauai's Avatar
Wouldent stiffer springs make the VT louder? Since its more load that the cam has to push down on to.
Old Jul 28, 2008 | 02:49 PM
HondaKid_1's Avatar
Default Re: (slowtegkauai)
bump anyone eles>?
Old Jul 28, 2008 | 07:38 PM
HondaKid_1's Avatar
wow no one eles can help>?
Old Jul 28, 2008 | 08:43 PM
jdmer329's Avatar
just do a valve adjustment to be sure if you think that really might be it.
Old Jul 28, 2008 | 10:46 PM
HondaKid_1's Avatar
Default Re: (jdmer329)
thats the problem i dont know what it could be.
Old Jul 29, 2008 | 05:21 AM
ruffrhyder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKid_1 &raquo;</TD></TR><TR><TD CLASS="quote">thats the problem i dont know what it could be.</TD></TR></TABLE>
Quit be a lazy *** and check your valve clearances already. You've had like 3 people already tell you to recheck your valve clearances since you did the valve adjustment and you most likely did it wrong, have someone who's experienced do it and see how it comes out. Also, why did you install stiffer springs, do you actually plan on installing aftermarket cams?
Old Jul 29, 2008 | 05:23 AM
ruffrhyder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostin_GSR &raquo;</TD></TR><TR><TD CLASS="quote">An upgraded valvetrain has been known to make alot more noise from the head as well.</TD></TR></TABLE>
Not my cars, i've used supertech, RM and S2 springs and my valvetrains don't make much more noise, I guess it depends on who does the valve adjustment since everyone's sense of 'slight drag' on the feeler gauge is different and will effect clearances.
Old Jul 29, 2008 | 02:53 PM
HondaKid_1's Avatar
Default Re: (ruffrhyder)
Me lazy? i have done 4 valve adjustments to recheck my own work.
http://www.team-integra.net/se...D=485
followed that down to the tee.
Slide the correct feeler gauge between the cam lobe and lifter. For example, if your range is .006-.007, the clearance is good if the .006 feeler fits and the .007 feeler does NOT fit. If the .007 fits or the .006 does not fit, then the clearance needs adjusting. You want to make it so the smaller of the two feelers fits and the larger doesn't. Over time your clearances will likely loosen, I've never seen any case of them tightening so tighten as much as you can to fit that smaller feeler in.
Sound right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruffrhyder &raquo;</TD></TR><TR><TD CLASS="quote">
Also, why did you install stiffer springs, do you actually plan on installing aftermarket cams? </TD></TR></TABLE>
yeah i do plan on putting aftermarket cams in. does it matter? the valvesprings were free. a gift from a friend.
I dont know what the problem but let me asure you its not the valves. valves would make more noise as the rpms went up i know. i have had my run ins with lose rockers. so unless you wanna give some imput that is helpful than dont post in here.
Old Jul 29, 2008 | 03:06 PM
ruffrhyder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKid_1 &raquo;</TD></TR><TR><TD CLASS="quote">for some reason when the motor heats up something is ticking really loud. it sounds like valves. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKid_1 &raquo;</TD></TR><TR><TD CLASS="quote">I dont know what the problem but let me asure you its not the valves.</TD></TR></TABLE>
What makes you so sure it's not the valves, did you have the valves inspected or valve job performed? Were the valves lapped to ensure proper seating?
Who knows, like others have said, their car's made more noise after installing stiffer springs, your car might be the same way.
Old Jul 29, 2008 | 06:02 PM
HondaKid_1's Avatar
Default Re: new built motor problems..... (ruffrhyder)
the fisrt quote was the first post. and now im pretty damn sure its not vlaves cause i have looked over everything. the valves did not make noise before i took it apart and i lapped them after how could it be messed up now? im gonna replace my lma's and see if that fixs anything.
Old Jul 29, 2008 | 07:59 PM
all-mtr-teg's Avatar
When you rebuilt the head and installed the LMA's, did you soak them in oil while the head was being worked on, or at least before you installed them?
Old Jul 29, 2008 | 09:54 PM
HondaKid_1's Avatar
Default Re: new built motor problems..... (all-mtr-teg)
no they were in the head when it was hot tanked and milled. got it back and it sat for like 5 days then i put wd40 in them and rust came out. so thats my bet.
Old Jul 30, 2008 | 05:26 AM
ruffrhyder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKid_1 &raquo;</TD></TR><TR><TD CLASS="quote">no they were in the head when it was hot tanked and milled. got it back and it sat for like 5 days then i put wd40 in them and rust came out. so thats my bet.</TD></TR></TABLE>
Like all-mtr-teg said, the lma's should have been stored in oil while the head was being worked or soaked in oil for a few minutes before reassembling the head.
csmith21
Feb 26, 2010 08:25 PM
HondaKid_1
Jul 28, 2008 10:47 PM
spoonhatchblack
Nov 6, 2005 09:38 PM
scUba-stEve
Jan 14, 2005 03:55 PM
