GReddy Relic running (4)additional RC 310' on the d16 Sohc Turbo?
I am getting the GReddy Relic from a friend, it runs 4- 310RC injectors. The motor uses the stock injectors, the 310's only come on when boost is sensed.
The 4 additional injectors are mounted on the bottom side of the intake manifold.
Would this set-up work better then the V_AFC hack?
Afc still tends to run rich, so this is why i would like to get some info on anyone that has used the GReddy Relic.
Peter
Peter
With rods and pistons i want to run 10lbs or more, and the pistons will be a lower compression then the original ones..
I will also be using the MSD ignition system, and tune it on a dyno so it will be done right.
Short cuts cost in the end, and I do not like to waste money.
djvtoner
Jul 28, 2005 10:45 AM
CivicRaping
Apr 28, 2005 11:22 AM
