1997 accord will not start after new motor put in.
Old Jul 25, 2008 | 03:18 PM
str8JDMteggy's Avatar
Default 1997 accord will not start after new motor put in.
I swaped the motor on my 97 accord se. Now the car turns over, has fuel pressure at the rail, has spark,but the plugs/cyliders are dry. So im thinking that the injectors are not fireing. Any idea why? Thanks in advance.
Chris
Old Jul 26, 2008 | 08:38 AM
whltng's Avatar
Default Re: 1997 accord will not start after new motor put in. (str8JDMteggy)
Check your grounds.......
See what I went through: https://honda-tech.com/zerothread/2332993
Good Luck!
Old Jul 26, 2008 | 10:20 AM
I only remember putting the ground on by the driver side motor mount and the one by the battery, what others am i missing?
Old Jul 26, 2008 | 10:25 AM
shutgun21's Avatar
Default Re: (str8JDMteggy)
i believe there should be another one on the intake manifold, by IAT sensor somewhere. cant think of any other ones
Old Jul 27, 2008 | 04:00 PM
Cant find one by IAT sensor. I connected the 2 grounds, one by the battery and one by the driver side mount. I pulled one of the injector plugs out and it even has 12v.
Old Jul 27, 2008 | 05:19 PM
Ek9LbC's Avatar
check your wiring
Old Jul 29, 2008 | 08:28 AM
Wiring all good any other ideas?
Old Jul 30, 2008 | 06:10 AM
bseriescrxsi's Avatar
there is a ground on some models at the thermostat housing or around there i believe
Old Jul 30, 2008 | 06:38 AM
GhostAccord's Avatar
Default Re: (bseriescrxsi)
Did you hook up the engine wire harness grounds? There are two locations on the top of the motor. One is a main ground (G101) it is located at the end of the intake manifold. It should be attached via one of the bolts that attach the vacuum T to the manifold. The other is on top of the valve cover. These two grounds are in the wire loom that contains the injector wires.
Modified by GhostAccord at 11:44 AM 7/30/2008
Old Jul 30, 2008 | 08:46 PM
Ill check for those grounds tomorrow. Thanks for the help.
Old Jul 31, 2008 | 06:39 PM
mouab18c1's Avatar
timing could be a possiblity if you messed with it......
kevin916sfs
Aug 13, 2019 05:49 PM
Big-Chris
Jul 24, 2013 08:32 PM
Kris's turbo
Dec 22, 2012 11:47 AM
tomkeklak
Aug 14, 2005 01:38 PM
