rear mount for b swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HASport's Instructions »</TD></TR><TR><TD CLASS="quote">Test fit the rear mount on the rear engine cross-member. The rear mount uses THE TWO BOLT HOLES NEAREST THE DRIVERS SIDE OF THE CAR. Note the area directly in front of the mount, as shown in the picture to the right. This area of the rear cross-member will need to be bent down to clear the rear engine bracket. Test fit the bracket on the mount after bending the cross-member to make sure enough was bent down.
and don't forget to make the dent below the shock tower for alternator clearance.
</TD></TR></TABLE>and don't forget to make the dent below the shock tower for alternator clearance.
RTW DC2R
Sep 10, 2003 11:41 AM
