Are you happy with your "mini-me?"
Old Jul 21, 2002 | 11:46 AM
photonjedi808's Avatar
Default Are you happy with your "mini-me?"
I've been wanting to this swap for a while and just picked up a Z6 head last week.
I'm going to be using
A6: block, intake mani, dist, cam gear
Z6: head
y8: fuel pressusre regulator
stock si ecu w/ ghetto vtec switch (for now)
Before I put it on I just wanted to know if you guys are hapy with your mini-me setup. Any installation tips would also be helpful.
thanks
Old Jul 21, 2002 | 11:53 AM
RuthlessEF-9's Avatar
Default Re: Are you happy with your "mini-me?" (photonjedi808)
use a z6 manifold so you make your upgrading options alot better
you can mount a b series throttle body on your d series you can put an LS, GSR, Even type R. I got a JG throttle body for a Type R on my Z6
just a suggestion. Also if you can try get a hold of a fiels Vtec controller
you can adjust your fuel curves on your non vtec ecu to a simlar curves of a vtec ecu or even better. Y8 fuel pressure regulator won't bolt on the A6 rail nor will the Y8 rail boltup to the ag manifold. Thats why i say go with the z6 so you can use that vtec regulator or you could also just get a b&m fuel pressure regulator. I did all this back yard mini me stuff and i pulled a 15.5 consistant and 86 mph hour. just letting you know all the stuff i went through.hope you have fun and hope i helped you out
Old Jul 21, 2002 | 11:59 AM
USDM 4G VTEC's Avatar
yeah
i can say i am happy
but i will be even more when i get to boost it to 5 psi!
Old Jul 21, 2002 | 01:03 PM
daniel89civ's Avatar
Default Re: Are you happy with your "mini-me?" (JDM EF9)
i am happy with my minime i can keep with alot of cars , but i still want a B series engine.
_ remember that you have to modify your distributor
_i use a y8 head gasket ,i also read that z6 head gasket its the thinest one, i buy it from adealer its like 45$dollars or less
_buy 92-95 timming belt 30$
_i am using a frend pg7 and fuel pressure its at 34ps1
_timming i dont have a timming belt, i can tell by moving the diztributor its advance
Old Jul 21, 2002 | 02:05 PM
I have the Z6 intake manifold but I heard that the sensors are different than the A6. The Z6 FPR is damaged so i'm looking for other options before I get an adjustable one. I can get a Y8 FPR free but I guess it doesn't matter since it won't bolt up. I'm also going to use a new A6 head gasket (since I already bought one)
Old Jul 21, 2002 | 02:25 PM
SpoonPL's Avatar
Default Re: Are you happy with your "mini-me?" (daniel89civ)
34 psi of fuel, **** i'm running between 50 and 55 !!!
Try to find a pg7 ecu form a 88-89 teg, you can then take full advantage of the motor
PL
(Edit: wrote fuel instead of full)
[Modified by SpoonPL, 3:26 PM 7/21/2002]
EGandDArida
Nov 12, 2008 08:18 AM
foowitdaredek
Jun 10, 2007 12:03 AM
jonleeone
Jun 23, 2005 02:20 PM
trooper0641
18
Aug 29, 2004 03:04 AM
crx(gator)
Jul 21, 2002 07:57 PM
