shorter 4th gear make a big difference?
I'am building the d16z6 that is in my ej1 over the next couple months. I want to get everything dialed in together to work the best they can.
My goals...
~325whp @20psi which should yield ~120mph trap speed.
basically with the tires I plan on running I will be hitting the end of 4th at ~140mph with using the current gearing
or ~125mph if I use a 4th gear from the zc transmission.
will this yield a pretty big difference?
My goals...
