Suspension & Brakes Theory, alignment, spring rates....
Koni Dampening Controller
Old Jul 24, 2008 | 11:42 PM
Pre_4_Me's Avatar
Default Koni Dampening Controller
Would it be possible to hook up a tein or greddy dampening controller to a set of Koni shocks?
Old Jul 26, 2008 | 05:55 PM
johnlear's Avatar
Banned
Default Re: Koni Dampening Controller (Pre_4_Me)
What a strange question. You can do a lot of things with enough determination and money, but I'd think it would be a rather pointless exercise. Assuming it is even possible, it would involve possibly costly mods and cost, and the result may not be all that great...
Why not just use Koni parts? Koni dampers have much better adjustable valves than just about any other brand, and while the 'stock' Konis are generally fitted with only a rebound adjustment, you can have bump adjusters fitted. Using Koni parts would ensure that you actually can do it, the result will be OK, and the cost will be reasonable (or at least reasonably reasonable).
Old Jul 26, 2008 | 07:57 PM
PIC Performance's Avatar
Default Re: Koni Dampening Controller (johnlear)
I think he means the EDFC from Tein.
Old Jul 26, 2008 | 09:43 PM
beanbag's Avatar
yes
ghetto rigging may be required
Modified by beanbag at 10:52 PM 7/26/2008
Old Jul 28, 2008 | 05:32 PM
omnirage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnlear &raquo;</TD></TR><TR><TD CLASS="quote">...and while the 'stock' Konis are generally fitted with only a rebound adjustment, you can have bump adjusters fitted.</TD></TR></TABLE>
Someone shed light on this, please! I have only rebound adjustment...how costly is this surgery? I'm about 45min from Ground Control here in Cali.
Old Jul 28, 2008 | 05:37 PM
beanbag's Avatar
Default Re: Koni Dampening Controller (omnirage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omnirage &raquo;</TD></TR><TR><TD CLASS="quote">
Someone shed light on this, please! I have only rebound adjustment...how costly is this surgery? I'm about 45min from Ground Control here in Cali.</TD></TR></TABLE>
Very costly
Old Jul 28, 2008 | 10:17 PM
johnlear's Avatar
Banned
Someone shed light on this, please! I have only rebound adjustment...how costly is this surgery?</TD></TR></TABLE>
I only know it's possible, but haven't actually asked the cost.
I suspect that unless you're into some serious racing it's probably not important to have adjustable bump rate, my understanding is that rebound rate has far more influence on handling (thus why having adjustable rebound is more worth having than adjustable bump).
Be aware that most dampers (which includes most of those that come with spring / damper units that come as a set) that do have adjustable bump actually have very little range of bump stiffness, even if they may have a lot of adjustment 'clicks' (so little the adjustment is just about useless). I would expect Konis (with bump adjusters fitted) to be better than most in this respect, but don't know for sure.
Old Jul 30, 2008 | 12:38 PM
EK4civichatch's Avatar
You can send the dampers to Konis to have them converted to double adjustable, but bear in mind that you will be giving youself more room to mess up your setup if you don't know what your doing. If this is just a street car it really isn't neccesary.
Old Aug 1, 2008 | 06:59 AM
omnirage's Avatar
Default Re: (EK4civichatch)
Yeah, rebound adjusting is all I need. I just didn't know I could potentially do this.
JustAnotherRex
Suspension & Brakes
14
Nov 7, 2007 04:43 PM
ds0440
Suspension & Brakes
Jun 14, 2007 11:32 PM
2DoorBandit
Suspension & Brakes
Feb 17, 2006 04:02 AM
johnzm
Suspension & Brakes
Feb 8, 2006 11:29 AM
DR.DRum
Mar 20, 2003 05:27 AM
