car will not turnover! need help ASAP
Old Jul 24, 2008 | 10:20 PM
joshuma's Avatar
Default car will not turnover! need help ASAP
alright, i've searched and searched and searched and nothing that came up was of any help to my situation
i got in my car this morning pushed down the clutch and turned the key and absolutley nothing happens
all the accesories work i.e. lights, radio everything
it just will not turnover
as if the clutch peddle is not being pressed down.
if anyone can help me out with this problem, that would be most appreciated
thank you for the help in advance!
Old Jul 24, 2008 | 10:50 PM
Hawkze_2.3's Avatar
Default Re: car will not turnover! need help ASAP (joshuma)
OK, so what kind of car is it?
Have you checked out the clutch switch? Ignition switch?
Old Jul 25, 2008 | 04:51 AM
joshuma's Avatar
my bad
it's a 1991 prelude si
i haven't really checked much, just wanted to have some replys with some possible issues.
that way when i get from work i could jump on and test more than one.
Old Jul 25, 2008 | 07:13 AM
SKDRCR's Avatar
Default Re: (joshuma)
Disconnect the connector that plugs into the clutch switch and jump it/bypass it.
If it starts then you've found your problem.
Old Jul 25, 2008 | 08:01 AM
dagle's Avatar
Default Re: (SKDRCR)
and you're sure the battery is good?
Old Jul 25, 2008 | 12:55 PM
mafia's Avatar
Default Re: (dagle)
or mabe bad starter?
Old Jul 25, 2008 | 01:43 PM
joshuma's Avatar
battery is good.
starter is good.
when i turn the key starter has no click
it's as if the clutch is not being pressed at all.
Old Jul 25, 2008 | 02:31 PM
hondatunedbboy's Avatar
there is a rubber bullet looking thing that attaches to at the top of the pedal. it depresses the clutch switch when you push in the pedal. I've had that break on my 5th gen lude and a civic a time or two. check for rubber pieces on your floorboard..
Old Jul 26, 2008 | 12:48 AM
sup3rd's Avatar
Default Re: (hondatunedbboy)
try push starting it. if it starts up then its your starter
Old Jul 26, 2008 | 10:37 AM
S-LudeDan's Avatar
* B A N N E D *
see if you can start it while another car is giving you a jump. Also I was thinking that it might be an alternator issue, check that too.
Old Jul 29, 2008 | 08:42 PM
joshuma's Avatar
the car popstarts no problem
i just replaced the starter
still nothing.
Old Jul 30, 2008 | 03:30 AM
lude98SH's Avatar
check the voltages going to the starter. If you can figure out where you have power and where you dont we can figure out what component is bad. Because the fact that it pop starts tells me its not ignition or fuel related. You know its something to do primarily with the starting system. What year model is the car ?
Im looking for my 98. You should have 12v always at the starter solenoid that is directly hooked to the battery. Then turn the ignition switch, make sure you have power at the starter solenoid from the ignition switch. It is the little plug going to it on the top of the solenoid.
You replaced the starter and solenoid correct ?
Modified by lude98SH at 7:40 AM 7/30/2008
Old Jul 30, 2008 | 03:26 PM
joshuma's Avatar
brand new starter
brand new solenoid
i've tried everything i can think of
ignition cylinder
battery
alternator
starter
solenoid
fuses
EVERYTHING!!!
Old Jul 31, 2008 | 06:21 AM
lude98SH's Avatar
check voltages because if it pop started that tells me its most likely in the starting system circuit.
Old Jul 31, 2008 | 01:59 PM
did you check to see if the switch was being depressed while stepping the clutch pedal?
Old Jul 31, 2008 | 03:41 PM
lude98SH's Avatar
if that switch is bad he wont have 12v from that circuit at the starter solenoid.
Old Jul 31, 2008 | 04:54 PM
joshuma's Avatar
alright, fixed
thank you guys for all the help.
i feel like an idiot.
i checked the rubber bullet the extends when the clutch is pressed in.
reached my hand up a little further and felt a second bullet, a few plastic pieces fell.
i pressed the bullet in, turned my key and the car started right up
Old Aug 1, 2008 | 04:22 PM
told ya! happened to me before...twice i think.
Old Aug 1, 2008 | 10:56 PM
sup3rd's Avatar
hahahaa nicely done! makes perfect sense too. yay we all learned something lol
dannycraq
24
Sep 20, 2014 05:07 PM
magicmyst98
14
Sep 2, 2013 12:06 PM
viera
Sep 18, 2011 08:02 PM
atli126
14
Feb 16, 2005 04:17 PM
gumbybum
Feb 8, 2003 11:15 PM
