FS: 1999 EJ6 ~~ Clean all motor with taseful mods ~~ IOWA!
Old Jul 24, 2008 | 11:22 AM
dinko's Avatar
Default FS: 1999 EJ6 ~~ Clean all motor with taseful mods ~~ IOWA!
Contact: PM or Cell (515) 865-2157
Car: 1999 Honda Civic DX (coupe)
Color: (stock) Dark green metallic
Mileage: 75,xxx on body, 6,xxx on motor
VIN: Upon request
PRICE: <FONT COLOR="red">10,000 / obo</FONT>
I didn’t think this day would come so soon. The more I think about it though, the more it makes sense. With my last year of college steadily approaching, it’s time to redirect all the energy I put into this car and into my career. This is a fun hobby and racing is an itch I constantly have to scratch! Call it “getting outta the game” or whatever, but I’ll be back in a Honda before you know it!
I don’t owe a dime on this car. I’m not in a hurry to sell it. It will sit at my parents’ house under a car cover in a clean garage while I’m in college. If I don’t get what I want out of it, I’ll just keep it and add more parts to it next year!
There’s absolutely NOTHING wrong with this car. It’s perfectly streetable and very reliable. It was built up so I could drive it on sunny days, and take it out to the local auto-x events. With a few sway bars and a good driver, this car can be very competitive in the Street Mod class. I’ve only had the chance to take this car out once to the auto-x and it is absolutely a blast! It gets great gas mileage, cops never bother me, and my insurance is crazy low ($43 a month, as long as I keep it under 9k miles a year.)
<FONT COLOR="green">Clean title in hand! Money talks, so if you ain’t got it, don’t waste my time or yours. Now for all the little details: </FONT>
BLOCK
(Machined and hot tanked by Harvey’s in Norwalk, IA. Assembled by Adi Radoncic)
81.5mm B18C1
Decked .007”
Micro polished GS-R crank
ITR rods
RS Machine PR3 pistons (Compression is in the high 11:xx)
Hastings rings
ARP rod bolts
ACL rod and thrust bearings
New oil and water pump
New tensioner, spring, and timing belt
New oil strainer and oil pan gasket
Stock crank pulley
I always use Honda oil filters
HEAD
(Disassembled, hot tanked, bead blasted, and assembled by Harvey’s in Norwalk, IA)
Shaved and repainted valve cover in wrinkle black w/ kevlar spark plug cover
New valve cover gasket, washers, and castle nuts
Stock GS-R head, no porting
Mugen 2-layer head gasket
Stock valves (valves adjusted by Adi)
New valve seals
Rocket Motorsports m22x cams (w/ springs and retainer package)
AEM cam gears (3-bolt style with upgraded bolts from Fastenal)
ARP head studs
Hondata intake manifold gasket
Skunk2 intake manifold (gen.1)
ITR throttle body w/ coolant block off plate
AEM short ram intake
New thermostat
New upper and lower radiator hoses
TRANSMISSION
Stock GS-R tranny (non-LSD)
Honda/Acura MTF
New throw-out bearing
New passenger side axle
New passenger side axle oil seal
Resurfaced GS-R flywheel
ACT Street clutch
Edelbrock short shifter
Polyurethane shifter bushings
FUEL
Stock fuel rail
Stock regulator
RC 310cc injectors (w/ new o-rings)
Walboro 255hf fuel pump
IGNITION
New cap
New rotor
New NGK plug wires
New NGK spark plugs
EXHAUST
(very quiet setup)
New exhaust manifold gasket
New exhaust manifold nuts
Rage Tri-Y stainless steel header
2.5” mild steel piping (by Iowa Muffler & Brake)
Resonator (dunno how long it is)
Spoon Sports muffler
SUSPENSION
Blox Rear LCA’s
Omni-Power Full Coilovers (Street version, still 1 year warranty left)
Front “frame locks”
WHEELS/BRAKES
15” Rota Group-N’s (black w/ thin red lip, minty)
Dunlop Direzza’s 205/50/15 (plenty tread left)
Muteki open-ended lug nuts w/ key (black)
Front pads have plenty life left
Rear drums have been repainted with 1300 degree VHT paint
Brake lines have been fully re-bled with Valvoline SynPower brake fluid, which exceeds DOT 4 requirements
INTERIOR
MP3 CD player w/ remote
Upgraded front and rear speakers
GS-R shift ****
GS-R cluster
NRG short hub
Sparco 2” steering wheel spacer
Sparco steering wheel
Trunk area has been gutted
No floor mats
Non-smoker
Carpet and seats are very clean, no rips
EXTERIOR
Civic Si front lip
Spoon style side mirrors (non-powered)
Paint is not perfect, but it looks great for a stock paint job. There are less than a handful of visible dings, which can be removed with ease by a shop specializing in paint-less dent removal.
Rear bumper has a small crack right above the muffler opening. I bought the car like this and it’s never really bothered me that much. It’s not directly visible unless you get up right next to the car.
The front bumper has a small scuff right under the driver side headlight. This is also not very visible unless you kneel down and examine it closely.
TUNING
91 octane pump gas (around 30 mpg)
Chipped P28 ECU (OBD-1)
OBD-2b to OBD-1 jumper harness
Neptuned by SuprDave of Whip Factory
Perfect 900 rpm idle every time
6,000 rpm 2-step launch control
6,700 rpm v-tec crossover
9,300 rpm red line
Car put down 186whp / 122tq on the local Mustang Dyno while only revving to 8,700 rpm. (Dyno owners didn’t know how to operate the dyno) The dyno tuning was also done on a cheap Megan Racing (eBay) stainless header, which was obviously holding this setup back. It’s all I could afford at the time. The cams were also starving for more air in the top end (according to SuprDave.) A 68mm throttle body and some porting to the current intake manifold would really open up the potential of these cams. I’m confident this car would put down at least 200whp on a dynapack dyno if just the whole power band was utilized with the current setup.
OTHER
Brand new EverStart battery from Walmart
There’s a custom oil catch can kit running off the back of the block to help with blow-by gases through the piston rings. It is not a drain back system so you occasionally have to drain it manually. There’s plenty of room to do it so it’s really easy. It’s bigger than the Endyn unit and was fabricated by a shop I found on Honda-Tech, but I forgot the name.
All air conditioning stuff has been scrapped. A/C delete plug has been installed on the firewall. The mechanism for the A/C that’s usually located behind the glove box has been removed.
Power steering has also been removed in order to maximize engine power and “feel” for the car/road. Power-steering lines have been looped, and then T’d into a second clutch reservoir, which serves only as a “breather.” The breather helps the air bubbles left in the power steering lines escape so that you’re not pushing them around in a big circle. With the smaller Sparco steering wheel, it literally feels like you’re driving a go-kart. Lots of fun!
Headlight harnesses have been “tucked” underneath the fenders to leave the engine bay as clutter-free as possible. I’ve also soldered on new headlight harness plugs; that’s right, no more nasty/greasy *** plugs! Previous owner has painted front headlight housings black. They come equipped with yellow bulbs and it looks pretty nice. The coolant overflow reservoir has also been tucked under the firewall; right in front of the radiator.
The two lower motor mounts have been filled with 3M-window weld, as well as the upper passenger side motor mount. The driver side upper mount has been left untouched, but the rear motor mount has an ES bushing insert. If you’ve read before that filling these mounts will cause your car to vibrate uncontrollably to a point where it’s undesirable, forget what you heard, cuz this car idles at the red light like stock! Without spending $300-400 on solid motor mounts, I think this is the second best option in an attempt to minimize the motor flexing during acceleration.
Any unnecessary plugs on the engine harness have been traced, de-pinned and removed. I then rewrapped the whole harness in fresh wire loom and quality 3M electrical tape. I “tucked” it behind the motor and out of view to the best of my ability to make it look as clutter-free as possible.
Just about every seal or gasket I could replace was replaced when the motor was rebuilt. I have a manila envelope full of receipts and part numbers for most of the engine parts to prove this.
The motor/car has never seen any kind of snow or winter weather. I have driven it in the spring rain a few times, but it always gets a full wash and scrub inside and out the following sunny day.
PICS
I have a set of 15" GS-R "fat fives" with some track rubber mounted on them. 2 Toyo & 2 Hankook with plenty tread left on all four. I can has pics of those later? If someone gives me a good offer these are going with the car! I also have a 5th fat five that didn't hold air so we scrapped the tire, but the rim is in perfect shape, and that can go too!
These are the most current pics I have of the engine bay.
http://www.dinkodesign.com/civ...0.jpg
http://www.dinkodesign.com/civ...4.jpg
http://www.dinkodesign.com/civ...8.jpg
http://www.dinkodesign.com/civ...9.jpg
http://www.dinkodesign.com/civ...2.jpg
Interior
http://www.dinkodesign.com/civ...1.jpg
http://www.dinkodesign.com/civ...3.jpg
http://www.dinkodesign.com/civ...5.jpg
These are a few weeks old, but everything is still the same
http://www.dinkodesign.com/civ...7.jpg
http://www.dinkodesign.com/civ...6.jpg
You can see the frame locks in these pics (they're red; under the headlights)
Modified by dinko at 2:06 PM 7/29/2008
Modified by dinko at 4:13 PM 8/28/2008
Old Jul 24, 2008 | 02:07 PM
dinko's Avatar
Default Re: FS: 1999 EJ6 ~~ Clean all motor with taseful mods ~~ IOWA! (dinko)
didn't know the midwest forum moved so fast! bump!
Old Jul 24, 2008 | 07:00 PM
civic4lif's Avatar
bump for a clean *** car GL with the sale
Old Jul 24, 2008 | 08:32 PM
dinko's Avatar
Default Re: FS: 1999 EJ6 ~~ Clean all motor with taseful mods ~~ IOWA! (civic4lif)
thanks
Old Jul 24, 2008 | 08:36 PM
HondaEJ7's Avatar
real clean.
do you have a buddy named Gabe? i think i seen ur car in his pics a while back. he bought some hx wheels from me a longggg time ago
bump
Old Jul 24, 2008 | 08:51 PM
dinko's Avatar
Default Re: (HondaEJ7)
haha don't you know...i am the REAL gabe bauman!
Old Jul 25, 2008 | 11:11 AM
type-G's Avatar
Default Re: (dinko)
bump, for a stand up guy. and a really clean ride. hate to see it go.
Old Jul 26, 2008 | 06:57 AM
dinko's Avatar
Default Re: (type-G)
thanks g! i'll probably regret selling this one cuz i regret selling all my hondas lol but school first!
Old Jul 26, 2008 | 07:08 AM
MJobe's Avatar
Default Re: (dinko)
Clean clean clean
Ill vouch
Old Jul 27, 2008 | 07:30 AM
dinko's Avatar
bandwidth might be exceeding for my pics soon
Old Jul 27, 2008 | 08:11 AM
MJobe's Avatar
photobucket is owning you.
Old Jul 28, 2008 | 07:13 AM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">do you have a buddy named Gabe? i think i seen ur car in his pics a while back. he bought some hx wheels from me a longggg time ago</TD></TR></TABLE>
Haha...yes. I remember that. We met halfway between DSM and Chicago. I traded those last fall.
I'll be sad to see Dinko's car get sold. Good luck buddy.
Old Jul 28, 2008 | 11:48 AM
Nautical_Star's Avatar
Default Re: (gabebauman)
Sad to see a clean coupe go away. You'll be back Dinko...
Old Jul 28, 2008 | 12:05 PM
dinko's Avatar
Default Re: (Nautical_Star)
photobucket is owning this page. i'll be back with the pictures later today i gotta upload them all to another server.
Old Jul 28, 2008 | 12:06 PM
dinko's Avatar
Default Re: (dinko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nautical_Star &raquo;</TD></TR><TR><TD CLASS="quote">Sad to see a clean coupe go away. You'll be back Dinko...</TD></TR></TABLE>
where you been hiding old buddy?
Old Jul 28, 2008 | 04:33 PM
kptrulee's Avatar
Default Re: (dinko)
you didnt even break it in yet?
Old Jul 28, 2008 | 05:57 PM
Default Re: (dinko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dinko &raquo;</TD></TR><TR><TD CLASS="quote">
where you been hiding old buddy? </TD></TR></TABLE>
Question is where have you been hiding.
Old Jul 29, 2008 | 10:29 AM
dinko's Avatar
hah inside man. this summer has just been humid! hate iowa!
where's all the low-ballers in the house cmon i wanna see your best offer!
Old Jul 29, 2008 | 10:46 AM
gabebauman's Avatar
Default Re: (dinko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dinko &raquo;</TD></TR><TR><TD CLASS="quote">Where's all the low-ballers in the house cmon i wanna see your best offer! </TD></TR></TABLE>
I have $19.12 in my paypal.
Old Jul 29, 2008 | 10:51 AM
dinko's Avatar
damn that wouldn't even buy me a year of web hosting...
Old Jul 29, 2008 | 11:08 AM
dinko's Avatar
Default Re: (dinko)
pics are back up!
PRICE LOWERED! i wanna sell this before school starts so low ball me all you want!
Old Jul 29, 2008 | 11:21 AM
gabebauman's Avatar
Default Re: (dinko)
Dude...I want them frame locks!
Old Jul 29, 2008 | 11:25 AM
dinko's Avatar
hah no parting out yo!
Old Jul 29, 2008 | 03:14 PM
Default Re: (dinko)
Give me the motor, my shell could use it.
Old Jul 30, 2008 | 08:12 AM
dinko's Avatar
haha. if i was parting the car out i would. the motor is brand new!
