Ok...Big, weird problem with my 98 lude...help?!!
Old Jul 24, 2008 | 08:23 AM
IMHARD2's Avatar
Default Ok...Big, weird problem with my 98 lude...help?!!
Ok, so my lude just randomly cuts off, during idling and even while driving!! My mechanic says that it's my factory alarm triggering the fuel pump cut off to engage. Does that sound right? Or is he a moron? If he's correct, does anyone know what can cause that to happen? I really need my car back, and I feel that he needs all the help that he can get!! Any helpful pointers?? Thanks
Old Jul 24, 2008 | 08:31 AM
Hawkze_2.3's Avatar
Default Re: Ok...Big, weird problem with my 98 lude...help?!! (IMHARD2)
Most likely the ignition switch if you loose all power when it goes off....it's very common and there was a recall. Also a very easy fix.
Old Jul 24, 2008 | 10:45 AM
IMHARD2's Avatar
Default Re: Ok...Big, weird problem with my 98 lude...help?!! (Hawkze_2.3)
i don't lose all power....it's just like you turn the car on enough to be able to roll up the windows and the stereo's still on and all...
Old Jul 24, 2008 | 11:25 AM
DVS Luder's Avatar
i have a 98 prelude and it cuts off randomly while driving and while at idle. my problem was the ICM and coil being faulty. however, my car had other symptoms such as the tach jumping around, i dunno if you have that. but if it does, definitely check ignition components.
Old Jul 24, 2008 | 11:32 AM
IMHARD2's Avatar
Cool...i gave the local dealership my vin and the ignition switch recall wasn't done on it, so that should fix it!
Old Jul 24, 2008 | 08:51 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMHARD2 &raquo;</TD></TR><TR><TD CLASS="quote">Cool...i gave the local dealership my vin and the ignition switch recall wasn't done on it, so that should fix it!</TD></TR></TABLE>
Elvis1977
Oct 29, 2018 10:08 AM
S1mpl3xity
Mar 4, 2011 05:47 AM
quickspool
Dec 7, 2010 02:08 PM
JDM-EJ698
Dec 30, 2006 03:53 PM
Revi
Apr 9, 2004 02:26 PM
