Rear Lower Control Arm Bushings Removal
Old Jul 24, 2008 | 05:03 AM
Stadler's Avatar
Default Rear Lower Control Arm Bushings Removal
I have a drivers side Rear Lower Control arm, that the bolt broke on (one closest to brake caliper). I have the control arm off, but was wondering how to get the old bushings out to change them? Also, the bolt (what's left of it) is seized on the control arm so I can't get a jigsaw in there to cut it out.
Thanks in advance
Old Jul 24, 2008 | 05:36 AM
dem0nk1d's Avatar
you try pushing it out with a vise. i use what ever socket would fit on the bushings metal collar, and then on the other side of the arm have a peace of pipe longer and wider than the bushing so it can come out.
Old Jul 24, 2008 | 08:50 AM
Stadler's Avatar
Default Re: (dem0nk1d)
Thanks. I'll give it a shot
Old Jul 24, 2008 | 02:57 PM
Crx Jimmy's Avatar
Default Re: (Stadler)
drill a bunch of holes through the rubber and get the center out, then use a hacksaw and saw through the outer sleeve, bend the outer sleeve in and then hit out with a hammer
Old Jul 24, 2008 | 06:22 PM
Mad_Scientist's Avatar
Default Re: (Crx Jimmy)
Burn it out
Old Jul 25, 2008 | 08:34 PM
Stadler's Avatar
Default Re: (Mad_Scientist)
Thanks All. Ended up Burning it out. Now it's tiime to locate the bushings. Nobody has them, and I am told they are two seperate kits. Wondering now if I should just buy new Arms. Any suggestions?
Old Jul 26, 2008 | 09:51 AM
Crx Jimmy's Avatar
I have a new energy suspension control arm set if you want it, and yes its 2 different parts control arm bushing and then the shock bushings, I might have the shock bushings as well left over from the master kit, Ill have to go take a look
Old Jul 26, 2008 | 01:52 PM
dem0nk1d's Avatar
just buy some new stock, bushings. can't go wrong with them.
corkss
10
Mar 19, 2009 07:00 PM
20ls01
Oct 14, 2007 07:50 AM
MaXiMuS1701
Jun 29, 2007 10:12 PM
thisboyjulio
Oct 23, 2006 08:34 PM
Hyb
Feb 2, 2005 05:55 PM
