exahust or no exhaust?
Old Jul 24, 2008 | 04:18 AM
MIKEuBEEZY's Avatar
Default exahust or no exhaust?
this the 2nd time i posted this topic. the 1st time people just spoke about back pressure and other stuff that didnt answer my question. i have a 1991 crx si (stock except for short ram intake) and as of right now i am running it without the stock on. dont get me wrong i know its loud and i can get a ticket, but that doesnt really bother me. my main concern is, it messing up my engine not running exhaust? and also a buddy of mine told me it adds more power because they is no restriction from the stock exhaust. is that true?
Old Jul 24, 2008 | 05:06 AM
Radim's Avatar
Default Re: exahust or no exhaust? (MIKEuBEEZY)
Yes, you do get more power because of less restriction, which is why most race cars run open headers. Don't think you can cause damage to your engine though. I'd rather run an exhaust though.
Old Jul 24, 2008 | 05:13 AM
Red_ED8's Avatar
Default Re: exahust or no exhaust? (Radim)
Being you have a stock motor your really not going to see (or feel) any significant gains. I would just put the stock muffler back on, but it's your car.
Old Jul 24, 2008 | 09:46 AM
kyle1jzsupra's Avatar
get a 2.5 inch exhaust system made to fit ur car
Old Jul 24, 2008 | 10:22 AM
SIred91's Avatar
Rainman
Default Re: (kyle1jzsupra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyle1jzsupra &raquo;</TD></TR><TR><TD CLASS="quote">get a 2.5 inch exhaust system made to fit ur car </TD></TR></TABLE>
That is WAY too big for a honda unless you have some serious work done or a swap with work done.
Old Jul 29, 2008 | 06:56 AM
jon4honda's Avatar
i have a 2.5 on my stock 89 hatch motor with a flowmaster i no not very ricey but everyone kept getting tickets as did i with no exhaust when i got my car running the first time.....but to answer your ? yes its loud and depending where you live and how leaniant cops are you can run no exhaust with no harmful effects to your motor
Old Jul 29, 2008 | 08:20 AM
taylor1's Avatar
Default Re: exahust or no exhaust? (jon4honda)
you can suck valves run no exhaust
Old Jul 29, 2008 | 08:30 AM
jdmd15crx's Avatar
Default Re: exahust or no exhaust? (taylor1)
There is really no reason to run with no exhaust unless you are boosted or have a built motor. ur not gonna notice any differance in power its just gonna be loud as hell. ive heard you can damage ur valves by doing that bc theres no back pressure and a stock engine cant handle that.
Old Jul 29, 2008 | 09:05 AM
playaP's Avatar
if your gonna be street racin it or just reving high alot ,blown head gaskets, bent valves, oh and less low end power. Back pressure in the exhaust is very needed with stock motors id say.
Old Jul 29, 2008 | 09:21 AM
jdmd15crx's Avatar
Default Re: (playaP)
i agree, well said
Old Jul 29, 2008 | 09:31 AM
SIred91's Avatar
Rainman
Default Re: (jdmd15crx)
You are idiots, please read this and learn something instead of beleiving the bullshit that is coming out of you NOOB mouths.
Must I school some more children?-----------------------------------------------------
The myth: “engines need some backpressure.”
One of the most misunderstood concepts in exhaust theory is backpressure. People love to talk about backpressure on message boards with no real understanding of what it is and what its consequences are. I'm sure many of you have heard or read the phrase "engines need some backpressure" when discussing exhaust upgrades. That phrase is in fact completely inaccurate and a wholly misguided notion.
How the myth came about:
It is easy to see how this misunderstanding arises. Lets’ say that Max puts a 3-inch system on his normally aspirated car. He soon realizes that he has lost power right through the power band. The connection is made in his throbbing brain….
Put on 3" pipe = loss of backpressure = loss of power.
Max erroneously concludes that you need backpressure to retain performance. He has ignored the need for exhaust gas velocity to get that scavenge effect.
The other myth: “engines can get burned valves from not enough backpressure”
How this myth came about:
The other reason why people say "backpressure is good" is because they hear that cars (or motorcycles) that have had performance exhaust work done to them would then go on to burn exhaust valves. Now, it is true that such valve burning has occurred as a result of the exhaust mods, but it isn't due merely to a lack of backpressure.
The internal combustion engine is a complex, dynamic collection of different systems working together to convert the stored power in gasoline into mechanical energy to push a car down the road. Anytime one of these systems are modified, that mod will also indirectly affect the other systems, as well.
Now, valve burning occurs as a result of a very lean-burning engine. In order to achieve a theoretical optimal combustion, an engine needs 14.7 parts of oxygen by mass to 1 part of gasoline (again, by mass). This is referred to as a stochiometric (chemically correct) mixture, and is commonly referred to as a 14.7:1 mix. If an engine burns with less oxygen present (13:1, 12:1, etc...), it is said to run rich. Conversely, if the engine runs with more oxygen present (16:1, 17:1, etc...), it is said to run lean. Today's engines are designed to run at 14.7:1 for normally cruising, with rich mixtures on acceleration or warm-up, and lean mixtures while decelerating.
Getting back to the discussion, the reason that exhaust valves burn is because the engine is burning lean. Normal engines will tolerate lean burning for a little bit, but not for sustained periods of time. The reason why the engine is burning lean to begin with is that the reduction in backpressure is causing more air to be drawn into the combustion chamber than before. Earlier cars (and motorcycles) with carburetion often could not adjust for his.
Once these vehicles received performance mods that reduced backpressure, they tended to burn valves because of the resulting over-lean condition. This, incidentally, also provides a basis for the "torque increase" seen if backpressure is maintained. As the fuel/air mixture becomes leaner, the resultant combustion will produce progressively less and less of the force needed to produce torque.
Some basic exhaust theory
Your exhaust system is designed to evacuate gases from the combustion chamber quickly and efficiently. Exhaust gases are not produced in a smooth stream; exhaust gases originate in pulses. A 4 cylinder motor will have 4 distinct pulses per complete engine cycle; a 6 cylinder has 6 pulses and so on. The more pulses that are produced, the more continuous the exhaust flow. Backpressure can be loosely defined as the resistance to positive flow - in this case, the resistance to positive flow of the exhaust stream.
Backpressure and velocity.
Some people operate under the misguided notion that wider pipes are more effective at clearing the combustion chamber than narrower pipes. It's not hard to see how this misconception is appealing - wider pipes have the capability to flow more than narrower pipes. So if they have the ability to flow more, why isn't "wider is better" a good rule of thumb for exhaust upgrading? In a word - VELOCITY. I'm sure that all of you have at one time used a garden hose w/o a spray nozzle on it. If you let the water just run unrestricted out of the house it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will flow out at a much, much, faster rate.
The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be traveling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you want make sure the pipe is wide enough so that there is as little backpressure as possible while maintaining suitable exhaust gas velocity.
Backpressure in its most extreme form can lead to reversion of the exhaust stream - that is to say the exhaust flows backwards, which is not good. The trick is to have a pipe that that is as narrow as possible while having as close to zero backpressure as possible at the RPM range you want your power band to be located at. Exhaust pipe diameters are best suited to a particular RPM range. A smaller pipe diameter will produce higher exhaust velocities at a lower RPM but create unacceptably high amounts of backpressure at high rpm. Thus if your power band is located 2-3000 RPM you'd want a narrower pipe than if your power band is located at 8-9000RPM.
Many engineers try to work around the RPM specific nature of pipe diameters by using setups that are capable of creating a similar effect as a change in pipe diameter on the fly. The most advanced is Ferrari's which consists of two exhaust paths after the header - at low RPM only one path is open to maintain exhaust velocity, but as RPM climbs and exhaust volume increases, the second path is opened to curb backpressure - since there is greater exhaust volume there is no loss in flow velocity. BMW and Nissan use a simpler and less effective method - there is a single exhaust path to the muffler; the muffler has two paths; one path is closed at low RPM but both are open at high RPM.
So why is exhaust velocity so important?
The faster an exhaust pulse moves, the better it can scavenge out all of the spent gasses during valve overlap. The guiding principles of exhaust pulse scavenging are a bit beyond the scope of this doc but the general idea is a fast moving pulse creates a low pressure area behind it. This low pressure area acts as a vacuum and draws along the air behind it. A similar example would be a vehicle traveling at a high rate of speed on a dusty road. There is a low pressure area immediately behind the moving vehicle - dust particles get sucked into this low pressure area causing it to collect on the back of the vehicle. This effect is most noticeable on vans and hatchbacks which tend to create large trailing low pressure areas - giving rise to the numerous "wash me please" messages written in the thickly collected dust on the rear door(s).
Conclusion.
SO it turns out that engines don't need backpressure, they need as high a flow velocity as possible with as little backpressure as possible.
Old Jul 29, 2008 | 10:21 AM
jdmd15crx's Avatar
Default Re: (SIred91)
im not a complete idiot i took 3 years of automechanics. im not sayin i know everything but it does seem to me that cars that run with no exhaust dont seem to last very long whether it be a back pressure problem or not. id still recommend running a 2.5 inch exhaust with no cat, you still get good exhaust flow and hp and ur on the safe side. thats my opinion from experience. why take unecesarry risks. now if ur running boost, supercharger, or an all motor setup and you have high out put then thats great runnin straight headers or down pipe actually helps but not on a stock setup. you can pickup catback systems off ebay for $160 that work just as well as skunk2 or any other name brand and still sound great.
Old Jul 29, 2008 | 08:41 PM
Red_ED8's Avatar
SIred91 is 100% right, there is no need... I repeat... NO NEED for back pressure. Just SCAVENGING. And the reason you've noticed that cars don't last when running open headers is because if a person is dumb enough to run open header on or even near a public street then they can't be that great of a engine builder or tuner. So please don't be another ricer or just another LOUD *** SLOW Honda for the muscle car guys to rag on.
Old Jul 29, 2008 | 10:36 PM
Radim's Avatar
Conclusion.
My car backfires, is that enough backpressure and pulses? lol!!
Old Jul 30, 2008 | 04:19 AM
jdmd15crx's Avatar
Default Re: (Radim)
wow ppl can copy and paste to make them sound smart im impressed
Old Jul 30, 2008 | 05:07 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmd15crx &raquo;</TD></TR><TR><TD CLASS="quote">wow ppl can copy and paste to make them sound smart im impressed</TD></TR></TABLE>
You're the dummy who "took 3 years of automechanics" (even though your only 20, which would work out to mostly "highschool" courses) and doesn't understand the basics of your exhaust system.
Old Jul 30, 2008 | 10:38 AM
jdmd15crx's Avatar
Default Re: (gibsanez)
i clearly stated that it ur running boost then it would be ok but i wouldnt do it with a stock setup, whats the point. why dont you go read a book or something.
Old Jul 30, 2008 | 10:46 AM
jdmd15crx's Avatar
You dont even have an argument as to what ur talking about. when you reduce too much back-pressure to none. Most of the time it's even more than needed so the velocity of the exiting gasses gets slowed... As in your piping is WAY too big... let's say 3" on N/A car... No back pressure... but yet it's too big for the gasses for shoot out fast. back pressure is needed for low end torque.. that is if u decide u need any. if you have an exhaust system that has next to no back pressure, the gasses will leave the engine quickly, right? backpressure will keep some of the exhaust gasses somewhat near the engine during the intake stroke, keeping the engine warmer for a complete combustion. will little or no back pressure, the engine will run slightly cooler in lower rpms resulting in incomplete combustion... incomplete combustion = less power and more power is what we all want rite? hows that for 3 years of "highschool courses". Get educated.
Old Jul 30, 2008 | 10:50 AM
Red_ED8's Avatar
OMG..... why is this thread still open? The OP isn't even in this argument. Toad please lock this before more spreads.
Old Jul 30, 2008 | 10:51 AM
one-cam's Avatar
why run no exhaust??? does it make u feel good when people stare at u when ur revvin it down the street? the ENVIRONMENT needs u and u need it so save it
Old Jul 30, 2008 | 10:52 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmd15crx &raquo;</TD></TR><TR><TD CLASS="quote">You dont even have an argument as to what ur talking about. when you reduce too much back-pressure to none. Most of the time it's even more than needed so the velocity of the exiting gasses gets slowed... As in your piping is WAY too big... let's say 3" on N/A car... No back pressure... but yet it's too big for the gasses for shoot out fast. back pressure is needed for low end torque.. that is if u decide u need any. if you have an exhaust system that has next to no back pressure, the gasses will leave the engine quickly, right? backpressure will keep some of the exhaust gasses somewhat near the engine during the intake stroke, keeping the engine warmer for a complete combustion. will little or no back pressure, the engine will run slightly cooler in lower rpms resulting in incomplete combustion... incomplete combustion = less power and more power is what we all want rite? hows that for 3 years of "highschool courses". Get educated.
You still dont understand the difference between flow velocity and flow capacity....too big exhaust actually creates back pressure, reducing flow velocity. Retard.
Josh_With_The_S2K
Honda S2000
29
Jan 25, 2008 03:16 PM
2fasttypes
20
Aug 19, 2007 09:37 PM
HS2G
Jul 21, 2005 10:30 AM
righteyeblind
Jan 11, 2004 07:33 PM
racinskittle
Aug 6, 2003 09:52 AM
