B18C starter question
I'm trying to solve the infamous Spoon FW grind issue with USDM Integra Denso starters. I found a shop that has mitsuba starters but the guy told me that they come in two sizes, large and small. He is recommending the smaller one which is from a JDM DC2 ITR motor. Is the JDM ITR starter the same as the USDM 99-00 Civic SI starter? Please help before I lose all the teeth on my fw. Thanks
Rob
Rob
For those who don't know, what he's referring to is the problem that USDM starter teeth/flywheel teeth are different from JDM starter/flywheel teeth, and if you try to mix and match it causes problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lopey »</TD></TR><TR><TD CLASS="quote">Do you know if any B series mitsuba starter is compatible with the spoon fw?</TD></TR></TABLE>
Sounds like any JDM b-series starter will work.
Does anybody know why they designed different teeth count? Maybe to get more torque becuase of the higher compression on the jdm motor?
I went and picked up the JDM ITR Mitsuba starter today. I installed it and did about 10 starts in a row with out any grinds. I'm pretty sure my stock starter would've ground by then. Success! Thanks.
Rob
Rob
Keyed ITR
Dec 7, 2003 10:52 AM
Tommy_Gunns
Jan 24, 2003 03:08 PM
