JB weld on valve cover??
Old Jul 23, 2008 | 07:45 PM
VTECth1s's Avatar
Default JB weld on valve cover??
Might be a ridiculous question. Can you use JB weld on the valve cover? I want to put 2 ports in it. Drill 2 holes, jb weld the 2 ports into the valve cover. It's for a breather tank on a turbo setup. Rather then welding 2 ports on it professionally. Thanks, hope that makes sense.
Old Jul 24, 2008 | 05:42 AM
miller's Avatar
Default Re: JB weld on valve cover?? (VTECth1s)
no
Old Jul 24, 2008 | 06:47 AM
Flashmn's Avatar
Default Re: JB weld on valve cover?? (miller)
x2
jbweld =
Old Jul 24, 2008 | 07:41 AM
RC000E's Avatar
Default Re: JB weld on valve cover?? (Flashmn)
They make A/N fittings that are "compression" fittings. They use a nylon seal on the backside, so it's a no weld/no leak deal.
Old Jul 24, 2008 | 08:31 AM
HMTforlife's Avatar
Don't listen to these idiots, it will work fine if you prep the surface.
Old Jul 24, 2008 | 09:07 AM
H22_TURBO's Avatar
Default Re: (HMTforlife)
like HMTforlife said, just prep it well.
mine has been jb'd for 2years and have not cracked loose/leaked or had any problems with it.
cheap but it works perfect for me.
Old Jul 24, 2008 | 09:14 AM
VTECth1s's Avatar
Default Re: (H22_TURBO)
That's what I was thinking. Definitely have to prep it well, easy part. What do you guys suggest using to make the ports, just your typical electric drill?
Old Jul 24, 2008 | 11:50 AM
under_boost's Avatar
Default Re: (VTECth1s)
why not just get it done right?
Old Jul 24, 2008 | 12:07 PM
VTECth1s's Avatar
Default Re: (under_boost)
Of course, but I like DIY projects. Having it professionally done is my last option.
Old Jul 25, 2008 | 04:06 AM
then take it to a buddies house and diy it with a tig. i just don't understand boogering up your valve cover and potentially have issues to say "yup. did it myself".
Modified by under_boost at 10:02 AM 7/27/2008
Old Jul 25, 2008 | 09:56 AM
welfarepc's Avatar
whatever, u can wirewheel the JB weld off easy if u need to. do it up!
it wont leak. prep well, mix evenly, apply evenly.
use atleast 1/2inch hose
post up pics on HMT when ur done
Old Jul 25, 2008 | 10:13 AM
VTECth1s's Avatar
Default Re: (welfarepc)
lol, sounds good. Just wanted to see if anyone has done this as well.
Old Jul 26, 2008 | 09:13 PM
srmofo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by under_boost &raquo;</TD></TR><TR><TD CLASS="quote">why not just get it done right?</TD></TR></TABLE>
x2
Old Jul 27, 2008 | 02:13 AM
ptftw's Avatar
x2
Old Jul 27, 2008 | 04:08 AM
Flashmn's Avatar
Default Re: (ptftw)
Exactly... so x2 from me too.
Old Jul 27, 2008 | 09:55 AM
pepsi in a can's Avatar
* B A N N E D *
This is what I ask all my friend (the few) who rig ish up.
Old Jul 28, 2008 | 03:39 PM
mike93eh2's Avatar
Default Re: JB weld on valve cover?? (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">They make A/N fittings that are "compression" fittings. They use a nylon seal on the backside, so it's a no weld/no leak deal.</TD></TR></TABLE>
theyre called bulkhead fittings. you can get them and everything else on summit.
i did my valve cover with bulkhead AN fittings and works just as good as welding it.
Linh.
Welding / Fabrication
Dec 21, 2012 04:08 PM
eksessiv
Feb 15, 2011 07:27 PM
vtec.dc2
May 6, 2005 01:40 AM
allmotorhatch
Mar 8, 2005 09:46 AM
