FS. 1995 Fully Built Turbo GSR In Wisconsin
Last Deal Fell Tru so lets try this again.
Testing Waters on my Teg. Not in any hurry but for right price she's out the door. PLEASE NO LOW BALLERS OR STUPID COMMENTS. THANKS. WILLING TO ACCEPT TRADES OF YR. 06 07 08 HONDA CBR 1000, SUZUKI GSXR 1000, YAMAHA R1,or large CC Super Sport Bike, OR WAVE RUNNERS OF SAME YEARS.
IT is a 1995 GSR. I have receipts for major work performed. NO free Test drives! I want full amount in hand. Thank you.Please make offer.
®Balanced, Blue Printed and sleeved B18C by King Motor Sports
84mm Bore
®ITR Cams
®J E Pistons
®Eagle Rods
®New Main Bearings
®ITR Balanced Crank
®New oil pump
®New Mugen low temp thermostat
®Samco red coolant hoses
®J G Intake Manifold
®King Big bore throttle body
®LoveFab Ram Head exhaust manifold (2800° Ceramic Coated)
®Moroso 5 Qt oil pan
®Precisions version of the Garrett twin scroll gt35r turbo– Polished housing (2800° Ceramic Coated Turbo Housing)
®40mm Tial Wastegate
®HKS sequential blow off valve
®Integra type R cylinder head Port matched, 3-angle competition valve job
®Type R Cams
®Supertech valve train
®ARC intercooler
®Mugen Hard Motor Mounts
®Fluidyne 40mm radiator
®Precision 1000cc injectors
®3-inch stainless steel exhaust
®3-inch stainless steel down pipe (2800° Ceramic Jet Coated)
®Walbro fuel pump 225 LPH
®AEM fuel filter, fuel rail, cam gears
®Aeromotive FPR #13109 with Aeromotive SS-6&10 lines
®KMS oil catch can
®Magnacore 8.5 plug wires
®MSD full sport compact ignition
®Custom upper & lower intercooler pipes
®ACT stage 3 six puck racing clutch
®Act 8LB Flywheel
®Quaife Limited slip
®Built Trans (hardened and carbon coated components)
®Enkei J10 17x7 rims w/Falken Azenis rt615 205 40 17
®Front Brembro cross-drilled and slotted rotors
®Rear Brembro cross-drilled rotors
®Brembro front & rear brake pads
®Tokico Illumines coil-overs
®DC sports front & rear strut tower braces
®Hondata P72 ECU
®Hondata S300 computer system
®Hondata Independent gear boost controller
®Sparco Flash 5 steering wheel
®Sparco Pedal Set
®Full chrome moly roll cage
®Sparco racing seats
®Sparco 4 point Harnesses
®Jdm Air bag Eliminator Plate
®JDM Center counsel Eliminator
®JDM double Din Stereo Eliminator Plate
®Mugen Sweat Socks
® 01 ITR Stock Front Bumper cover
® 98 Stock Head lights
® 98 Stock Rear Bumper
®Gauges auto meter phantom series (fuel pressure, oil pressure, volts, boost, nitrous,(nitrous gauge was used only for intercooler sprayer)
Air/fuel) 5.5” auto meter tachometer with shift light
®Was dyno tuned by King Motorsports New Berlin, WI
[IMG]
[/IMG]
84mm Bore
®ITR Cams
®J E Pistons
®Eagle Rods
®New Main Bearings
®ITR Balanced Crank
®New oil pump
®Type R Cams
®ARC intercooler
®KMS oil catch can
®Act 8LB Flywheel
®Hondata P72 ECU
®Sparco Pedal Set
®Mugen Sweat Socks
[IMG]
[/IMG]
501hpintegra
Nov 15, 2007 12:48 PM
501hpintegra
Oct 24, 2007 08:20 AM
501hpintegra
Aug 10, 2007 08:52 AM
