bad head gasket?
Old Jul 23, 2008 | 12:00 PM
leroyb's Avatar
Default bad head gasket?
i bought this 91 crx for 500 buckets but has a lil problem the car idles super low and when u try to go it feels like if its building pressure after a couple of seconds the rpms will start going up and the car moves but when i stop it turns off..another thing the car is leaking radiator fluid form the timing cover side of the motor u guys think is a bad head gasket or wat???
Old Jul 23, 2008 | 12:12 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: bad head gasket? (leroyb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leroyb &raquo;</TD></TR><TR><TD CLASS="quote">i bought this 91 crx for 500 buckets but has a lil problem the car idles super low and when u try to go it feels like if its building pressure after a couple of seconds the rpms will start going up and the car moves but when i stop it turns off..another thing the car is leaking radiator fluid form the timing cover side of the motor u guys think is a bad head gasket or wat??? </TD></TR></TABLE>
500 buckets? Wow!
Your water pump is under the timing cover, I'd check that first.
To check your headgasket; Check cylinder compression, easy as that. Find somebody with a compression gauge. Also, milky oil, excessive white smoke is an indicator as well.
$10 says you have a bad waterpump... might as well replace the timing belt while you're at it.
Old Jul 23, 2008 | 12:15 PM
leroyb's Avatar
Default Re: bad head gasket? (LSVTEC 91 Civic)
yea cuz the oil is clean no smoke ill chech that for sure thankx ill paypal u those 10 bucks is ur right lol
Old Jul 23, 2008 | 12:17 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leroyb &raquo;</TD></TR><TR><TD CLASS="quote">yea cuz the oil is clean no smoke ill chech that for sure thankx ill paypal u those 10 bucks is ur right lol</TD></TR></TABLE> Make sure you get new o rings as well.
Old Jul 23, 2008 | 12:20 PM
leroyb's Avatar
is it hard to do???
Old Jul 23, 2008 | 06:26 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leroyb &raquo;</TD></TR><TR><TD CLASS="quote">is it hard to do???</TD></TR></TABLE>
No. Get a manual, Timing belt jobs are fairly easy.
Maureen57
Mar 21, 2007 12:30 PM
uberhaulin
Jul 5, 2006 05:36 PM
mrtoastyjr
Aug 9, 2004 06:58 PM
seditiouscivic
Apr 6, 2004 09:03 PM
simike
Aug 2, 2002 01:29 PM
