anyone tried anything in the bullseye s200 series
Old Jul 23, 2008 | 08:45 AM
spoolin turbo s's Avatar
Default anyone tried anything in the bullseye s200 series
any setups or dyno would be killer
Old Jul 23, 2008 | 10:28 AM
TheShodan's Avatar
Moderator
Default Re: anyone tried anything in the bullseye s200 series (spoolin turbo s)
Which S200? S256, S258? S300 series in S200 covers?
Old Jul 23, 2008 | 11:24 AM
PSI2HI's Avatar
Former Vendor
9:1 GSR motor
This graph is a fewyears old and there are a few diffent turbine housings options available for these now that are better suited for the application.
S256 @ 22 psi:
S256 @ 25 psi:
S256 @ 30 psi:
S256 @ 32 psi:
Modified by PSI2HI at 1:55 PM 7/23/2008
Old Jul 23, 2008 | 12:49 PM
LastGenEK's Avatar
Default Re: anyone tried anything in the bullseye s200 series (PSI2HI)
Im not a turbo pro but i never seen a GSR Make almost 450 ft lbs of tq?
Old Jul 23, 2008 | 03:11 PM
tony413's Avatar
PSI2HI do you mind telling us what octane gas was used for each pull
Old Jul 23, 2008 | 03:33 PM
PSI2HI's Avatar
Former Vendor
Default Re: anyone tried anything in the bullseye s200 series (tony413)
110 octane if i remember correctly. This test was done 2.5 years ago.
Old Jul 23, 2008 | 03:53 PM
tony413's Avatar
oh ok that 22psi is nice but i plan on using 93 octane so oh well
Old Jul 23, 2008 | 08:36 PM
turbodano's Avatar
The S259 will make plenty of power @ 19psi.
Old Jul 24, 2008 | 06:35 AM
Default Re: anyone tried anything in the bullseye s200 series (turbodano)
is the s256 the smallest turbo from bullseye? if not what do they make smaller
im looking at something in the 450-500whp max
do they still make ett 50 trims and if so what AR turbine housings are available
it would be on a 20v VW so im only revving to 7500 and am looking for something for the best spool and capable of no more than 500whp
Old Jul 24, 2008 | 07:46 AM
morgan@synapse motorsport's Avatar
some BW 256 results on my motor:
20psi
24psi
above 24psi
Old Jul 24, 2008 | 08:04 AM
tony413's Avatar
Default Re: anyone tried anything in the bullseye s200 series (mike@synapse motorsport)
nice numbers mike what octane ?
Old Jul 24, 2008 | 08:18 AM
i beleive we used c16. dont quote me on that cuz it might have been c12. but definately one of the 2.
Old Jul 24, 2008 | 08:33 AM
SuperTeg95's Avatar
Looks like you have definatly maxed it out at 550. Im sure that mid range dip isnt helping much either.
Old Jul 24, 2008 | 10:00 AM
turbodano's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin turbo s &raquo;</TD></TR><TR><TD CLASS="quote">is the s256 the smallest turbo from bullseye? if not what do they make smaller
it would be on a 20v VW so im only revving to 7500 and am looking for something for the best spool and capable of no more than 500whp</TD></TR></TABLE>
We have just added the S252 and S247 to our line up. If you are looking for 450whp The S252 or S256 is what i would go with.
Old Aug 21, 2008 | 02:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodano &raquo;</TD></TR><TR><TD CLASS="quote">
We have just added the S252 and S247 to our line up. If you are looking for 450whp The S252 or S256 is what i would go with. </TD></TR></TABLE>
i would really like some more info on these turbos
has anyone used one yet?
also how much MAX WHP would each be good for and approx. spool on stock bore and stroke LS
it would actually be on a 20V1.8 VW motor and the closest honda comparison that i have seen is an LS motor until us VW guys change the head and put a cam in and then its comparable to a lsvtec motor
PSI2HI
Oct 15, 2010 06:02 AM
ChokeOnMySmoke
Jul 1, 2010 07:05 PM
IHaveTurbos
Welding / Fabrication
58
Mar 14, 2007 01:37 AM
