drivers side motor mount ( b series)
can anyne with a b series swap post a pic of yur drivers side mount, and what mount bracket did you use? my motor isnt lining up right. thakns
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thedudefromjerz »</TD></TR><TR><TD CLASS="quote">can anyne with a b series swap post a pic of yur drivers side mount, and what mount bracket did you use? my motor isnt lining up right. thakns</TD></TR></TABLE>
I want to say its the 90-93 teg mount but I think I'm wrong.
I know it should have two posts on it, in for an answer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eaglekper0046 »</TD></TR><TR><TD CLASS="quote">You need an aftermarket mount for the drivers side when swaping in a b motor</TD></TR></TABLE>
But the one that connects below the camshafts, above the timing tensioner I believe is the one he is asking about.
Anyone?
Anyone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thedudefromjerz »</TD></TR><TR><TD CLASS="quote">for the 90-93 teg parts you surced are yu talking about the t bracket? or the bracket under the timing belt cover?</TD></TR></TABLE>
you need both of those from a 90-93 integra
will the bracket under the timing belt cover from a 99-00 civic si work on a b18 block for my ef?
Modified by thedudefromjerz at 7:47 AM 7/24/2008
spooncivicsi
Welding / Fabrication
May 6, 2005 06:28 AM
