My car vibrates bad
Old Jul 22, 2008 | 11:08 PM
1fastefhatch's Avatar
Default My car vibrates bad
Hey im a nuub I have a 90 ef hatch si (A6) it has around 170xxxish on the origanal motor at idle it vibrates really hard my dash vibrates to i looked on alldata and there was a tsb for way back in the day it was a ground on the tps sensor i did it then relearned the idle i tryed the hazard fuse under the hood nothing worked?? It could be just old and tired but its still kickin the vibrating just bugs me. Oh and i have poly mount bushings would that make it vibrate has anyone else had this problem?? any ideas would be much appreciated
Old Jul 22, 2008 | 11:14 PM
EFstyle's Avatar
Default Re: My car vibrates bad (1fastefhatch)
i have motor mount insert from Prothane wich are a bit stiffer then Energy Suspsnsion inserts... any who... everything vibrates pretty bad... even one of my headlights makes crazy noises untill it idles down when cold.
Old Jul 23, 2008 | 05:07 AM
th3pwn3r's Avatar
I have Hasports B-series drag mounts and it vibrates pretty bad as well and there's nothing that can really be done about it unless I get bushings that are a bit softer which I wouldn't want to do. Vibration always has to go or exist somewhere.
Old Jul 23, 2008 | 05:58 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: (th3pwn3r)
Why are you guys running these hard mounts?
Old Jul 23, 2008 | 08:50 AM
kyle1jzsupra's Avatar
cuz thats how they like em. hard.
Old Jul 23, 2008 | 09:38 AM
Si-Samuri's Avatar
harder mounts provide better engine stability while launching the car. of course it will also cause it to vibrate the whole car at idle.
Old Jul 23, 2008 | 11:39 AM
KB91Hatch's Avatar
Default Re: (Si-Samuri)
true dat.....my friends eg is like a drivable *****.....his girl loves to ride in it!!!lol
Old Jul 23, 2008 | 12:31 PM
hotwater's Avatar
Default Re: (KB91Hatch)
lmao nice one
Old Jul 23, 2008 | 10:27 PM
Default Re: (kyle1jzsupra)
You mount them in the front and back torque mounts there pretty cheap too!! And when i turn on the head lights it gets worse same with hitting the brakes the draw of amps from the brake lights it almost seams like a starve of amperage??
Old Jul 23, 2008 | 11:17 PM
Radim's Avatar
Default Re: (1fastefhatch)
You can try a grounding kit, don't be cheap though, HKS had a special on them don't know if they still do, but they were 65 for the Cycle Earth kit.
Old Jul 24, 2008 | 10:04 PM
Default Re: (Radim)
Does the ground kit just go in place of all the factory grounds??
danny7560
May 11, 2015 07:34 AM
Hilary_duff
Dec 18, 2005 12:45 PM
jimby452
Oct 10, 2003 09:42 AM
bearboy80
Jul 9, 2003 01:49 PM
