valve cover bolts broke
Old Jul 22, 2008 | 09:40 PM
tdubbebawllin's Avatar
Default valve cover bolts broke
ok im a dumbass and over tourqued my vc bolts... the back one.. and the front left one....it dont appear to leak..one is broke where i cant see it and the other is sticking out.. any suggestions on what i can do?????thanks
Old Jul 22, 2008 | 09:45 PM
redef90si's Avatar
Default Re: valve cover bolts broke (tdubbebawllin)
I did the same thing when i was first learning.......Just go to the junk yards and take them off a scrap head or w.e.I believe you need a 14mm or a 12mm can't remeber? with an extension.Very easy to take off and put on gl.don't worry it looks bad right now but just get the 2 replacement ones and your
Old Jul 22, 2008 | 09:49 PM
Default Re: valve cover bolts broke (redef90si)
thee one is down in the hole and i cant get it out.. it broke at the bottom .. how would i get that screw out...and yeah im just learnin about civics and stuff..hopefully i dont have my d16y8 in there long ..wantin to put a b20 in it with a b16a1 head....but i need a fix untill i get enough cash
Old Jul 22, 2008 | 09:51 PM
redef90si's Avatar
are you saying it dropped in ur head Can you see it with the valvecover off?
Old Jul 22, 2008 | 09:59 PM
yea i can see it but its not stickin out
Old Jul 22, 2008 | 10:02 PM
redef90si's Avatar
get a magnet(the retracktable type)It looks like a wand;if you can grab the one and then just replace both you should be golden goodluck man.
Old Jul 22, 2008 | 10:08 PM
bobjohnson's Avatar
No hes saying the bolt broke off too low and he cant get it out.
For the one that you can still see thread above the head on, take vice grips and twist it out.
For the other one, get an easy out and drill it out of the hole... be careful not to damage the threads though. If you arent comfortable doing it, take it to a shop.
Old Jul 22, 2008 | 10:18 PM
Default Re: valve cover bolts broke (bobjohnson)
wats a easy out and yeah thats what im talkin bout....lol...
TUR3Ovtec
Jun 19, 2010 08:23 AM
PatrickGSR94
Nov 15, 2008 05:40 PM
EJ8 GSR-T
34
Jan 23, 2006 07:57 PM
ButterMule
Jul 27, 2004 01:02 PM
Type_Rydah
Dec 23, 2003 06:20 AM
