d16z6 mated with d16a6 tranny, do able?
ok ok... so my last post i should of looked at the faq's. but now i've searched and searched and i cannot find, the information i need. Fear not though that i'm just another person throwing random n00b Q's w/o looking first now. I've gotten a fill OBD 1 harness for his Z6, but now he is looking to buy a tranny. we do not want to use the z6's tranny cuz its all jacked up ( last person using this motor dumped it so low it ripped off one of the shifter linkage mount points ) so we were thinking it would be easier and alot cheaper if we got a a6 tranny from an si ef. my question now is will it mate up? and would i buy a flywheel for a z6, and then clutch kit for the a6?
thanks again for the help.
you have to pay attention to the year of the transmission though, cause the 88 and 89+ have a diffferent number of splines on the input shaft. As long as you get an 89+ trans, you can use the 90-2000 clutch and flywheel.
88 has 21 splines on the input shaft
89+ has 20 spline on input shaft
88 used 190mm flywheel
89 used 200mm flywheel
90+ used 212mm flywheel
you can get away with running a 88 trans on the z6 if you buy a 90+ flywheel and pressure plate, and a 1988 Honda Accord clutch disk.
you can run the 89-91 transmission with 90+ flywheel, clutch disk and pressure plate.
gdub604
Transmission & Drivetrain
Jun 12, 2014 05:07 PM
