ITR Sway Bar Question
i'm planning to put in a rear swaybar to my car.
Been looking around for a good deal and so far they're all about $400 for the ASR subframe brace, and a 22-24mm sway bar (either ctr, itr or asr bar) + all bushings and endlinks.
is this going to be the average price?
and will itr bars fit EKs? because i'm thinking about getting an asr brace for bout 180 and the itr bar for 120 with all bushings but the ITR bushings will not fit in a civic correct? so that leaves me with the option of getting an aftermarket adjustable endlink set for bout 70 bucks or so right?
which should i go for? an all in one package from weaksos or a mix and match here and there for slightly cheaper?
Just curious, but what about using a CTR bar? Is it longer so that the ends of the bar will be closer to being situated above the stock LCA endlink holes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">Just curious, but what about using a CTR bar? Is it longer so that the ends of the bar will be closer to being situated above the stock LCA endlink holes?</TD></TR></TABLE>
I think theyre actually shorter
Cause the ITR bars have to curve out further to clear the ABS
yo do you guys know if asr makes a sub frame brace for itr? i ordered one from jhp (on their site it says it fits all 94-01 model integras), box comes in and on the box it says all models excluding itr. So does that mean that there is two types, a non itr and itr, or do they just not make for itr?
00R101
Nov 15, 2004 05:39 PM
i got all my stuff for about 300
