00 Integra LS with susp. problems.. engine shutting off after bad bumps..
Well.. let me start off by saying it's been a while and hello to all that <3 H-T and keep it running :D
Ok, so i have a 2000 Integra LS, lowered on Function and Form type 2 coilovers, i installed them myself which is most likely where this problem arose, but i saved a good $100 installation fee in the process... so.. win some and lose some i guess.. My problem is whenever i hit a hard bump in the road, or just a jarring pot-hole or something of that sort, my whole freaking car shuts off and the ABS SRS lights come on, which i figure could either be trying to tell me the problem or just the fact the car shut off they pop on.. i dunno..
And to further confuse anyone reading this.. my CEL has never poopped on, and never has my computer located a problem.. i have a obd-II reader and check it regularly, just to be sure that anything hasnt popped up..
Anyone else experience something of this sort? Maybe the ABS sensor is out of whack? or... **** i have no idea..
PLEASE HELP!!!! haha thank you.
probably your ignition switch is going bad(the electrical portion).
The ABS and SRS lights are turning on, because the car was shut off, and then back to ignition "on".
Try and slightly move your key towards "off", while in the "on" position and see if what happens
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">probably your ignition switch is going bad(the electrical portion).
Try and slightly move your key towards "off", while in the "on" position and see if what happens</TD></TR></TABLE>
You read my mind. Ignition contact assembly is a possible culprit.
Thanks for all the help guys, i'm gunna try to fix this **** come next week..
