Plastic Pieces Over Wheels
Old Jul 22, 2008 | 06:11 PM
91civicsikid's Avatar
Default Plastic Pieces Over Wheels
So you know that plastic that covers your front wheels?
Are the 91 si and crx ones interchangeable?
Old Jul 22, 2008 | 08:06 PM
Driven's Avatar
Default Re: Plastic Pieces Over Wheels (91civicsikid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicsikid &raquo;</TD></TR><TR><TD CLASS="quote">So you know that plastic that covers your front wheels?
Are the 91 si and crx ones interchangeable?</TD></TR></TABLE>
psst... they are called hub caps
Old Jul 22, 2008 | 08:21 PM
4crx4me's Avatar
Default Re: Plastic Pieces Over Wheels (Driven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">
psst... they are called hub caps </TD></TR></TABLE>Or maybe he meant inner fenders?
Old Jul 23, 2008 | 01:22 AM
Default Re: Plastic Pieces Over Wheels (4crx4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">Or maybe he meant inner fenders?</TD></TR></TABLE>
winner! but i see what you were thinking. ha.
yes.. inner fenders
Old Jul 23, 2008 | 04:22 AM
JustAnotherRex's Avatar
yes.. inner fenders</TD></TR></TABLE>
I'd like to know too, my p/s door has been collecting water for a few months now since a deer took out my old fender and liner.
I doubt they are, since the outer fenders are significantly different but the wheel well may be close enough that they could be?
Based upon Honda's parts website it looks like Hatchback & 4 door are the same and CRX are different. Doesn't mean you can't use them though, that'd still need to be checked.
Old Jul 23, 2008 | 05:57 PM
4crx4me's Avatar
91 Si what? Civic Si? Versus CRX Si?
Check the part numbers?
Old Jul 23, 2008 | 06:48 PM
91civicsi
Old Jul 23, 2008 | 07:14 PM
Radim's Avatar
Default Re: (91civicsikid)
Ha! Mine is missing one too, 89 Hatch. It's the front driver side that is missing. No leaks though hasnt rained here in a while.
Old Jul 24, 2008 | 01:57 AM
well my thing is i want to put a CAI on but am afraid of sucking water.
Old Jul 24, 2008 | 02:01 AM
Radim's Avatar
You can get an AEM Bypass valve i think they are called, don't have to worry about sucking in water.
Old Jul 24, 2008 | 04:00 AM
Mugencrxsir1's Avatar
Some what... I swapped the crx fenders for civic fenders back in the day because I liked the fender flare better as the crx's fenders are much boxer than the civic's... They fit for the most part, but a little shaving might be needed to get the fender liners to fit properly...
So all I did was swap the fenders and front bumpers, and left the original inner fender liners alone and yes for the most part they worked just fine! The only problem I saw was that the civic and crx has different mounting points on the fenders for the wheel well liner... But if you can line up the hole correctly it works fine...
Hope this helps, and just to clarify I have an 88 Crx Si, and I swapped out the original fenders for 88 Civic fenders... The Model made no difference, hopefully this helps!
Later,
Old Jul 24, 2008 | 08:03 AM
Default Re: Plastic Pieces Over Wheels (Mugencrxsir1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">
Later, </TD></TR></TABLE>
Actually, Si fenders net you 3 hp and look cooler.
Old Jul 24, 2008 | 08:13 AM
Default Re: Plastic Pieces Over Wheels (JustAnotherRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustAnotherRex &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, Si fenders net you 3 hp and look cooler. </TD></TR></TABLE>
You know that's why I really put them on my rex to begin with!
Old Jul 24, 2008 | 08:23 AM
EL Vap133's Avatar
Do they even sell them for our EF/ED's anymore?
Well is they don't fit that is what zip ties are for.
Old Jul 24, 2008 | 06:31 PM
Alot of good information.
That aem deal is a good idea but not quite worth 50 bucks to me since I'm going turbo soon. But good idea.
And I found out the pieces the guy had were the wrong ones. He has the ones that go under the bumper.
em12nv
Mar 14, 2008 01:36 PM
Civic97s
Jul 4, 2007 12:52 PM
deadline
Mar 2, 2007 06:48 PM
r.wright
Nov 7, 2006 08:13 AM
EkLanta
Dec 19, 2005 12:00 AM
