Suspension & Brakes Theory, alignment, spring rates....
sqeaking shock
Old Jul 22, 2008 | 05:54 PM
LudeJdm's Avatar
Default sqeaking shock
i have a 92 prelude si w/ tokico blue gas shocks. the passenger front is making a sqeaking sound when i turn the wheel and while driving. i took it to a shop. my mechanic said that the shock isnt blown or cracked and its safe to drive. what can i do to make it stop sqeaking? its really annoying....
Old Jul 22, 2008 | 06:10 PM
khooper's Avatar
Default Re: sqeaking shock (LudeJdm)
Its probably your bushings. Unbolt it and clean those out and apply fresh grease like Slick Honey. If its the air shock, let all the air out and unscrew the air sleeve. Clean all that stuff up and re-grease with Slick Honey
___________________________
Hang up and drive.
Autopartswarehouse will there for you.
Old Jul 23, 2008 | 10:56 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: sqeaking shock (khooper)
Seeing how it's a Prelude, I would bet on the lower or upper ball joint being the culprit
Spray some silicon on the bushings/ball joints and push up and down on the car until you hear it go away- then you found your noisy component!
Old Jan 12, 2009 | 01:07 PM
gshatch's Avatar
did you ever find out what it was
Old Jan 14, 2009 | 10:27 AM
pworld2's Avatar
bushings. a neglected part by many honda owners.
thelizard_king
Suspension & Brakes
Aug 10, 2017 08:28 PM
Omega Blaze
11
Feb 26, 2015 01:57 PM
Janoush
Dec 14, 2007 08:34 PM
Turbo24sxt
Feb 28, 2006 04:17 PM
DarkBB4
Suspension & Brakes
Jun 6, 2005 05:25 AM
