battery light flickers when vtec opens it high revs
Old Jul 22, 2008 | 12:45 PM
jimmytriplets's Avatar
Default battery light flickers when vtec opens it high revs
hi guys... i hope you guys can help....
i just changed my battery and alternator...but the battery light comes on and sometimes flickers when i rev the car above 6k rpm or basically when the vtec opens.
at low speed or normal crusing speed everything is fine...
do you guys think its an alternator belt slip?
i drive an 91 EF3 with a b16a engine
thanks
Old Jul 22, 2008 | 03:07 PM
vtecb18c's Avatar
Default Re: battery light flickers when vtec opens it high revs (jimmytriplets)
possibly belt tensioner is lose...also check your grounds
Old Jul 22, 2008 | 03:52 PM
D16SiHatch's Avatar
Default Re: battery light flickers when vtec opens it high revs (vtecb18c)
try getting an alternator test, or maybe testing it yourself. The internal voltage regulator may be going out, and the voltage is spiking at high rpms.
Old Jul 22, 2008 | 06:33 PM
harmonator84's Avatar
Default Re: battery light flickers when vtec opens it high revs (D16SiHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">possibly belt tensioner is lose...also check your grounds</TD></TR></TABLE>
What I was thinking...check to make sure you did tighten your leads down on your battery too. Could jsut be when you really get on the throttle it is shaking the battery.
batallic
Jun 1, 2008 02:04 AM
daidilus
22
Dec 27, 2004 09:11 AM
pane93civhb
Sep 18, 2004 01:39 PM
ch4nq
Jul 20, 2004 07:02 PM
fe519
Sep 23, 2003 03:25 AM
