an other welder question
Old Jul 22, 2008 | 12:02 PM
integraturbo96's Avatar
Default an other welder question
I plan to start fabrication of manifold. So I check welder on ebay and I dont know wich will do the job.
http://cgi.ebay.com/THERMAL-AR...wItem
Does this one can do good weld on schedule 10/40
How about other cheap no name 300$ welder.
Old Jul 22, 2008 | 01:39 PM
jzz30's Avatar
Default Re: an other welder question (integraturbo96)
thats a similar welder i started on but it was the dragster 80.
that will probably be ok for sch10 but 40 may be pusning it especially because the dutycycle will be very low at say 70 amps. you wont be able to weld too long before it overheats and you need to let the welder cool.
if you can, try to get a welder with 100%duty cycle at a current you will be most likely welding at. that welder is probably good for 100% duty at maybe 40 or 45 amps. good for exhaust work
Old Jul 22, 2008 | 03:47 PM
jsw_1986's Avatar
Default Re: an other welder question (jzz30)
don't waste you money on that... if you're gonna do it do it right. I found mine on craigslist for $1800 brand new.
http://i56.photobucket.com/alb...5.jpg
Old Jul 22, 2008 | 11:26 PM
KENetics1's Avatar
No HF start, No thank you
Old Jul 23, 2008 | 03:21 AM
Default Re: an other welder question (KENetics1)
HF=high frequency??
Old Jul 23, 2008 | 09:50 PM
KENetics1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraturbo96 &raquo;</TD></TR><TR><TD CLASS="quote">HF=high frequency??</TD></TR></TABLE>
yeah, that machine your looking a has stratch start where you have to touch the material with the tungsten to get the arc to start. When you touch the material it contaminates the weld.
0bd1_Kanobe
Welding / Fabrication
May 19, 2011 09:52 AM
lsjon
Jun 13, 2007 01:42 AM
97EK9hatch
Mar 12, 2005 07:16 PM
menkio
Feb 12, 2005 08:27 AM
LankorDie
Sep 20, 2004 03:47 PM
