In and out of OVERDRIVE on a '93 HELP!!
Old Jul 22, 2008 | 05:51 AM
Mikebike125's Avatar
New User
Default In and out of OVERDRIVE on a '93 HELP!!
My '93 4-cyl LX has been quickly going in and out of overdrive (D4) when maintaining a constant hwy speed. Right now this is intermittant and I am wondering if there is some sort of sensor that controls this..... It goes into the D4 gear fine, it is just having some problems staying there. Is there a sensor or something that needs to get cleaned out?
BTW, the fluid has been regularly changed and it is still clear and does not smell burnt or anything like that.
Old Jul 23, 2008 | 03:35 AM
New User
Default Re: In and out of OVERDRIVE on a '93 HELP!! (Mikebike125)
Anybody?
Old Jul 25, 2008 | 07:13 AM
New User
I guess you guys are also stumped?
Old Jul 25, 2008 | 06:01 PM
1990AccordEX's Avatar
Default Re: (Mikebike125)
Try replacing the thermastat. A stuck open thermastat will cause the overdrive (torque convertor lock-up) to engage/disengage. Overdrive gets engage at opertating temperature, open thermastat equal incorrect opertating temperature.
Old Jul 25, 2008 | 08:25 PM
YeuEmMaiMai's Avatar
Default Re: (1990AccordEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990AccordEX &raquo;</TD></TR><TR><TD CLASS="quote">Try replacing the thermastat. A stuck open thermastat will cause the overdrive (torque convertor lock-up) to engage/disengage. Overdrive gets engage at opertating temperature, open thermastat equal incorrect opertating temperature.
Old Jul 28, 2008 | 03:53 AM
New User
I've had the thermostat replaced about two years ago and those problems haven't resurfaced so I don't think its that.
Someone said it might be the O2 sensor. How do I tell if the O2 sensor is gone? I don't want to replace it unless it is really gone because it costs so much $$$$$.
Old Jul 28, 2008 | 03:58 AM
there are only 2 reasons your car will slip in and out of over drive
1. ecu sees a temp problem with engine (IE not up to operating temp)
2. problem with trans
if your t-stat is OK, check your temp sensor.......
Old Jul 28, 2008 | 03:59 AM
New User
where is the temp sensor located? Is it in the water outlet housing?
mhernandez
Aug 31, 2011 06:12 AM
team 15
Transmission & Drivetrain
Oct 6, 2010 11:18 AM
timholub
Mar 10, 2005 12:20 PM
rtiadnoh
Mar 1, 2004 11:55 AM
