Koni yellows Question
Old Jul 21, 2008 | 10:41 PM
nekoabandoned's Avatar
Default Koni yellows Question
ok ive been riding around with a new set of koni sport 8041's and ive been bottoming out and getting wheel rub.
now ive searched and i cant find the answers i need , i need to know how to adjust the rebound and compression and what are they?
i need them as stiff as possible.
Old Jul 21, 2008 | 11:28 PM
Fatchance187's Avatar
Default Re: Koni yellows Question (nekoabandoned)
Get stiffer springs if your bottoming out.
Old Jul 21, 2008 | 11:30 PM
Default Re: Koni yellows Question (Fatchance187)
so theres no way to stiffen the strut to fix this?
either way i would still like to know how to adjust them properly
Old Jul 21, 2008 | 11:36 PM
I order to stiffen the shocs you should have gotten a couple of white ***** with your struts. put them on top of your struts, (they have slots to fit) and turn them to the right. That will stiffen them. If you still bottom out get stiffer springs, or raise your car. Gl
Old Jul 21, 2008 | 11:40 PM
oh one last question, this ones for a friend .
the 4 colors and numbers on kyb's , 4 is the stiffest right?
Old Jul 22, 2008 | 06:48 AM
Burnt Toast's Avatar
The spring takes the impact of the bump and the strut pushes back to normal length (called rebound). If you want a stiffer ride, you need to change the springs. A softer (slower) rate on the struts gives a plusher ride, more like a cadillac type ride.
92BlueCivic
Suspension & Brakes
Aug 21, 2006 03:31 PM
DLudist
Suspension & Brakes
Jan 14, 2006 11:19 AM
WannaHonda
Aug 3, 2004 08:32 AM
DA_TEG
May 2, 2004 01:29 PM
