header gets red hot after motor swap....normal?
I just swapped a low mileage d15b2 into my 89 Si hatch. Motor ran fine in previous car, no modifications made other than a new header (ebay cheapie). Car starts and runs perfect but headre gets so hot it melts the high temp ceramic coating (probably just high-temp paint
). It bubbles and is almost visibly red-hot. Is this normal, has this happened to anybody else?
No its not normal. Since theyre ebay theyre probably cheap metal with cheap paint on them, and the flow sucks. Get a real header.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvanFullwood »</TD></TR><TR><TD CLASS="quote">your timing is probably off</TD></TR></TABLE>
my guess as well
my guess as well
Timing is unchanged from when motor was pulled and there have been no other changes made. Header was not intended for a power increase but rather to facilitate easier future engine removal. And I had it laying around, freebie from a friend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobjohnson »</TD></TR><TR><TD CLASS="quote">No its not normal. Since theyre ebay theyre probably cheap metal with cheap paint on them, and the flow sucks. Get a real header.</TD></TR></TABLE>
Agreed!
Agreed!
how hot does it get?
can you touch it and give us an estimate of how hot it gets.
Bare hands are preferred in order to get a proper reading.
Hehe, it gets might hot. i'll check the cat tomorrow. That is a possibity because the car was spewing gobs of smoke which is why I swapped the motor in the first place. O2 sensor was caked on with soot, I should have thought to check the cat.
ApolloSpeed
Aug 27, 2005 07:22 AM
VTECR021
May 4, 2004 06:56 PM
