Head ?
Old Jul 21, 2008 | 07:59 PM
toolbox21's Avatar
Default Head ?
Whats a Better Head A Z6 Or Y8? , it will be going on a a6 block running obd1
Old Jul 21, 2008 | 08:38 PM
kyle1jzsupra's Avatar
i heard there almost the same but i am goin with the z6 cuz its easier 2 find
Old Jul 21, 2008 | 09:45 PM
89s1's Avatar
Default Re: (kyle1jzsupra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyle1jzsupra &raquo;</TD></TR><TR><TD CLASS="quote">i heard there almost the same but i am goin with the z6 cuz its easier 2 find</TD></TR></TABLE>
Almost the same in the sence that they came off d16 blocks..... but thats about it
The y8 head has quench pads that the z6 head doesn't have. Quench pads = good.
The z6 head is rumored to flow more and have more room for porting. Airflow = good.
they each have their strengths., but id hardly go so far as to say they are almost the same.
I've owned both.... neither found its way onto a block.... vtec is for b-sereis. i'll put an a6 head on my z6 block and run a bisi or exospeed cam for my next n/a D-sereis build.
Old Jul 21, 2008 | 09:48 PM
guy_from_nerk's Avatar
Default Re: (89s1)
1hp difference between a z6 and a y8, dont really think its going to matter much which head you run honestly.
Old Jul 22, 2008 | 08:01 AM
toolbox21's Avatar
Default Re: Head ? (toolbox21)
tru thanx, ive heard the Z6 cam is more aggressive and if you put a Z6 Cam in a Y8 its makes more power than just a Stock Z6, and Y8
Old Jul 22, 2008 | 08:10 AM
_Keith_'s Avatar
89s1 is right... z6 head is better then put the y8 intake mani on. But like said not much of a huge gain.
Old Jul 22, 2008 | 04:33 PM
89s1's Avatar
Default Re: (guy_from_nerk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guy_from_nerk &raquo;</TD></TR><TR><TD CLASS="quote">1hp difference between a z6 and a y8, dont really think its going to matter much which head you run honestly. </TD></TR></TABLE>
Engines aren't just cylinder heads you know....
The y8 and z6 are very different motors. The y8 has a swirl inducing primary cam lobe set. By opening one of the intake ports a little more it causes the air to swirl down into the cylinder allowing fuel and air to mix even better and spread itself around more evenly inside the cylinder.
Like i said, they are very different motors. just cuz they are both 1.6L sohc vtec and produce roughly the same power stock for stock, doesnt mean they are the same engine.
Old Jul 22, 2008 | 04:57 PM
toolbox21's Avatar
Default Re: (89s1)
Oh I Know It Going To Be Going On A Semi-Built A6 Block I Just Dont Have A A6 Head And I Have A Z6 And Y8 Head That Why I Wanted To Know Like Which One Had Better Flow And Get Some Info Like That, So Thanks For The Info Dude
Old Jul 22, 2008 | 05:37 PM
1991civicsi's Avatar
Default Re: (toolbox21)
Z6 - dizzy and timimg problems solved
Old Jul 22, 2008 | 06:24 PM
Default Re: (1991civicsi)
Y8 mani and hello leaness unless you run a FPR and tune the car.
Nichelson_Performance
Feb 3, 2009 10:07 PM
Commiecircusbear
Feb 12, 2008 01:21 PM
RedEK
Oct 24, 2003 10:30 PM
.Beaver
Aug 12, 2003 05:46 PM
