ef engine help???please
Old Jul 21, 2008 | 05:46 PM
92egvx's Avatar
Modified by 92egvx at 5:13 PM 7/29/2008
Modified by 92egvx at 5:15 PM 7/29/2008
Old Jul 21, 2008 | 05:48 PM
vtecb18c's Avatar
Default Re: ef engine help???please (92egvx)
you can put any d-series w/o vtec in the car without changing anything...if you pick one up with vtec than you need to run the vtec accesories wires(solinoid,VPS.ect) to a chipped p28
Old Jul 21, 2008 | 06:08 PM
92egvx's Avatar
Default Re: ef engine help???please (vtecb18c)
don't i got to change the intake mani so it will still run only 2 injectors??
Old Jul 21, 2008 | 06:09 PM
dr_latino999's Avatar
Default FV-QR
If you are avoiding rewiring, you will want to source the following engines for a direct replacement -
D15B2
D15B7
Old Jul 21, 2008 | 06:12 PM
92egvx's Avatar
Default Re: FV-QR (dr_latino999)
thanks that helped alot...i don't really know much about ef so thanks...
Old Jul 21, 2008 | 06:13 PM
92egvx's Avatar
yeah i was trying to avoid rewiring im not that good with wires
Old Jul 21, 2008 | 06:23 PM
sirtef9's Avatar
http://www.rywire.com
Old Jul 21, 2008 | 07:37 PM
driftam1's Avatar
Default Re: ef engine help???please (sirtef9)
please please please check the faq
https://honda-tech.com/zerothread/1508680
ive learned alot from it read learn and live it and search till you drop >>>.... it will take some time but u will realize that ur ?'s can be answered easily by reading a little then some 1 else tring to figure u out and trying to tell u an answer. search and read the faq and if u cant find anything for sure then ask like crazy
Old Jul 22, 2008 | 07:31 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">If you are avoiding rewiring, you will want to source the following engines for a direct replacement -
D15B2
D15B7
</TD></TR></TABLE>D15B7 is a MPFI OBD1 engine - D15B2 and D15B1 are the only DPFI engines
Rdnkgrl
Feb 5, 2009 03:54 AM
VTECROAR96typeR
Sep 27, 2008 03:29 AM
hellsyea2020
Jan 9, 2006 06:51 PM
sarniacivic
Dec 23, 2003 02:34 AM
