Will aeromotive fuel reg fit on my stock fuel rail!?
Got a problem with my fuel pressure...runnin stock setup at almost 60psi. I know this is too high. Stock psi is 37 for ITR. I got a B&M reg, but this reg, will not let me tune down. Lowest i got it was to 58psi. I got walbro 255lph, i thought of swapping out the walbro fuel pump for a stock fuel pump, until i made some phone calls and found out how much they were. over $300 for a stock fuel pump. I called RPM NYC out of Queens Village NY and they told me to put a aeromotive/ high end fuel reg on that will allow you to tune down. I was looking at the aeromotive fuel regs, between $150-$200. My first question, will the aeromotive fuel reg fit on my stock fuel rail?, do i need to get a new fuel rail/ bdl? Second question, I just need a universal fuel reg, anyone know of reputable places where i can get one?
Stock fuel pressure for an ITR is supposed to be 47-54 with the vacuum line off.
Is the aeromotive made to replace a stock FPR?
Before I believe you've stated you didn't want to spend a similar amount for and AEM FPR (which replaces the stock FPR).
Im not gonna spend 380+ on fuel pump, if i can get a reg, and rail that looks good and does the job at the same time. I got a B&M on there now, not doin the job. Im runnin real rich and smokin...
JDM swap. Everything else is fine...BLACK smoke is present. CEL even came on, daig. SYSTEM TOO RICH. I need to bring fuel down. Aeromotive is pretty popular, so will this fuel reg fit on my stock rail or will i need to buy a fuel rail also? BDL makes some fuel rails.
Its funny how sometimes just doing a (proper) valve adjustment and/or tune-up (cap/rotor/sparkplugs and maybe wires) cleans up this kind of situation.
Well, you'll probably still need a working FPR.
