TRANNY FLIUD
Old Jul 21, 2008 | 01:09 PM
turboy7's Avatar
Default TRANNY FLIUD
WHERE DO I CHECK THE TRANNY FLIUD ON A 94 CIVIC DX
Old Jul 21, 2008 | 01:22 PM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: TRANNY FLIUD (turboy7)
For a manual transmission, there's a filler bolt halfway up the passenger (I think) side of the transmission with a 3/8" squarehead. Take the bolt out and stick your pinky in. If you can feel fluid, it's right, assuming the car is on level ground. You'll have to do this from underneath the car.
Old Jul 21, 2008 | 04:05 PM
slowcivic2k's Avatar
Its a 17mm filler bolt, the 3/8 is the drain bolt.
The dipstick for automatics is right below the radiator fan. It should be yellow in color.
Old Jul 21, 2008 | 04:39 PM
Default Re: TRANNY FLIUD (slowcivic2k)
you're right, thanks.
Old Jul 21, 2008 | 08:39 PM
b18 hatch mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">Its a 17mm filler bolt, the 3/8 is the drain bolt.
The dipstick for automatics is right below the radiator fan. It should be yellow in color.</TD></TR></TABLE>
yep take the 17 mm out if fluid comes out u are good and if not add some make sure u park on level ground
Old Jul 23, 2008 | 10:48 AM
turboy7's Avatar
Default Re: TRANNY FLIUD (b18 hatch mike)
well i cant check it sittin on the ground cause it is so low but if i jack it up and put jack stand under both sides so its still level its ok right
Old Jul 23, 2008 | 12:28 PM
well... it needs to be level front to back too.
i-VTEC_DOHC
Honda Civic (2001 - 2005)
May 31, 2012 03:48 PM
Jimster480
33
Oct 5, 2009 05:21 AM
G2_Fella
Oct 10, 2008 04:43 PM
91tegra07
Mar 11, 2008 03:24 PM
aphex23
37
Jul 12, 2004 02:33 PM
