Suspension & Brakes Theory, alignment, spring rates....
Have Tein SS coilovers, but can I change out the springs??
Old Jul 21, 2008 | 12:44 PM
young noob #2's Avatar
Default Have Tein SS coilovers, but can I change out the springs??
hey guys, bought an ep3 early this year with tein ss's on it, but they spring rates are too soft......Does anyone know if I can buy the tein flex springs by themselves??? or is any spring compatible, sorry for the noob question, but I am just not sure, thanks all
Old Jul 21, 2008 | 01:39 PM
MAV3RiCK478's Avatar
Default Re: Have Tein SS coilovers, but can I change out the springs?? (young noob #2)
you can get tein springs from an authorized dealer or use any other spring as long as they have the same ID as your stock tein setup. but keep in mind the SS coilovers are valved for those spring rates, so it might be better to have them revalved and springs replaced through tein.
Old Jul 21, 2008 | 04:55 PM
Default Re: Have Tein SS coilovers, but can I change out the springs?? (MAV3RiCK478)
cool thats what i thought about the I.D. but the valving shouldn't be a problem though I think......It has adjustable dampning, wouldn't stiffening the damper's setting be the equal to raising the spring rates and leaving the damping at a lower level??? that may be a little farfetched and tricky to understand with the way I word it......hmmm maybe I will give Tein a call
Old Jul 21, 2008 | 04:57 PM
I forgot to add I am a poor college kid who's prized possesion and hard work of the last 14,000 dollars of 4 years, ek was stolen 6 months ago
Old Jul 25, 2008 | 07:38 AM
bump
Old Jul 25, 2008 | 11:01 AM
at full stiff the dampening level is meant to handle the spring on the coilover. in theory it can handle some extra spring stiffness but not much more than it was built for. which means if you put stiffer springs you will wear everything out faster because they are not matched, springs wear out faster because the damper can't handle the spring rate and vice versa.
Old Jul 25, 2008 | 11:39 AM
eksteve's Avatar
Yes tein sells diff. rate springs. Someone correct me if im wrong but i think Swift makes replacement springs for alot of coilivers. Just gotta be sure the size of the spring is correct.
Old Jul 26, 2008 | 06:23 PM
Default Re: Have Tein SS coilovers, but can I change out the springs?? (eksteve)
swift sells replacement springs for coilovers and also provides springs for zeal. but if he is gonna send them in to handle stiffer rates he might as well get tein springs.
you can swap any coilover spring to any setup as long as the ID is the same. i ran zeal springs on my omnipowers a long time ago and was very happy with them. changed the whole setup feel and responsiveness. they were the same stiffness but the zeal springs had less coils so there was no coil bind like the stock omni springs.
Old Jul 27, 2008 | 11:50 AM
projectTeG's Avatar
ive always been under the impression that the ss are valve to handle upto a certain spring rate, i forgot the rate, but it was from a convo from a tein rep.
Old Jul 28, 2008 | 11:28 PM
Default Re: (projectTeG)
out of the box the SS handle certain spring rates depending on the chassis but they can be custom valved and even shortened by sending them in.
Old Jul 29, 2008 | 11:57 AM
Default Re: (MAV3RiCK478)
man sounds like I have to talk to a tein rep. I just hope he isn't pulling my chain to get my money......thanks guys, any other input is more than welcomed
milanoteggy
Suspension & Brakes
12
Sep 10, 2011 04:38 PM
RaceInspired
Jan 28, 2008 01:04 PM
AlienKrOZ
Suspension & Brakes
Feb 25, 2006 08:57 AM
luder99
Apr 14, 2004 10:51 AM
integra2000
Sep 25, 2001 10:37 AM
