Need help installing Viper Alarm/Remote Start system!
Old Jul 21, 2008 | 10:35 AM
westonreed's Avatar
New User
Default Need help installing Viper Alarm/Remote Start system!
Alright, I bought a Viper 560XV Alarm/Remote Start system about 4 months ago and im just now getting around to putting it in. Im stuck on the first part of the wiring (wiring the heavy gauge wires). I have a Haynes Book for my car, so it has the wiring schematic for my car and i tried using that, but it is vague in places so I am still unsure if it is 100% correct.
Ok, There are 8 heavy gauge wires that have to hook up to the 5 wires coming from my ignition system.
This is what the diagram in my instructions booklet that came with the system says (these are the wires coming from the alarm/remote system):
Purple - (+) Starter output to starter (starter side)
Green - Starter input from ingnition (key side)
Red - (+) High current 12V input
Orange - (+) Output to accessory circuit
Pink - (+) Output to primary ignition circuit
Red - (+) (30A) High current 12V input
Pink/White - (+) Output to second ignition circuit
Red/White - (+) (30A) High current 12V input
These are the 5 wires coming out of my ignition:
White
Black/White
Black/Yellow
White/Black
Yellow
I am trying to figure out which wire from the alarm/remote system goes to which wire from my ignition. I have them in order the way I believe they should go, but i just have to be 100% sure on this one, obviously because i dont want to fry my car. I know how to do everything else and Ive installed alarm and remote systems on many cars, but this is my first civic and my first viper system and viper wont give me any wiring diagrams for my specific model because i am not a authorized dealer. Please help! Thanks!
westonreed is online now Report Post Edit/Delete Message
Old Jul 21, 2008 | 11:03 AM
addiction2bass's Avatar
Default Re: Need help installing Viper Alarm/Remote Start system! (westonreed)
what year civic? i might be able to help ya out with alittle wiring color codes....
i have them for my old 94civic EX and my 99civic EX. and i have alittle program that decent for wire colors just not very good on wire location.
Old Jul 21, 2008 | 11:04 AM
westonreed's Avatar
New User
Default Re: Need help installing Viper Alarm/Remote Start system! (addiction2bass)
its a 2000 si. thanks man
Old Jul 21, 2008 | 11:10 AM
this is for my 99 civic ex but im pretty sure its the same wiring.
its about the best i can find..
its not the best when i copy/paste it from my email i got.
hope it helps...
if its confusing i can forward you the email... just give me your email and ill forward it to you.
1999 Honda Civic DirectWire 2.0 Vehicle Information
All Products
Item Wire Color Polarity Wire Location
12 Volts white + ignition harness
Second 12 Volts
Starter black/white + ignition harness or
In 6 pin white plug behind fuse box
Second Starter
Ignition black/yellow + ignition harness
Second Ignition yellow + ignition harness
Third Ignition
Accessory white/black + ignition harness
Second Accessory
Third Accessory
Power Lock green/white - keyless entry module
The keyless entry module is white in color, and located in the drivers kick panel.
Power Unlock green/orange - keyless entry module
Lock Motor white/red drivers kick panel
Driver Unlock Motor blue/red drivers kick panel
Passenger Unlock Motor yellow/red keyless entry module
Parking Lights (-)
Parking Lights (+) red/black keyless entry module
Hazards
Left Front Door Trigger lt. green/red - OEM alarm plug
The OEM alarm plug is to the right side of the steering column. The plug is green.
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Dome Supervision same as doors
Trunk/Hatch Pin blue/black - OEM alarm plug
Tachometer blue test connector
Drivers side fire wall under hood in a 2 pin plug
Brake Wire green/white + brake switch
Parking Brake
Horn Trigger gray - OEM alarm plug
Wipers
Left Front Window (Up/Down) red/yel - red/blu A drivers door switch
Right Front Window (Up/Down) blu/yel - blu/org A drivers kick panel
Left Rear Window (Up/Down) grn/yel - green A drivers kick panel
Right Rear Window (Up/Down) yellow - yel/grn A drivers kick panel
Radio 12V white/blue + radio harness
Radio Ground black - radio harness
Radio Ignition yellow/red + radio harness
Radio Illumination red/black + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
Left Front Speaker (+/-) blue/green - gray/black +,- radio harness
Right Front Speaker (+/-) red/green - brown/black +,- radio harness
Left Rear Speaker (+/-) blue/yellow - gray/white +,- radio harness
Right Rear Speaker (+/-) red/yellow - brown/white +,- radio harness
Old Jul 21, 2008 | 11:13 AM
Player 2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by westonreed &raquo;</TD></TR><TR><TD CLASS="quote">its a 2000 si</TD></TR></TABLE>
Congratulations!! You just answered your question! Last time I checked, EVERY SINGLE USDM EM1 came with a manual transmission (someone please correct me if I'm wrong). It is not only foolish, but proves beyond a reason of a doubt that you HAVE NOT discovered the search button. FYI, it’s the only bold red button on the main H-T page.
I also highly suggest spending a ridiculous amount of time in the Audio/Security/Video forum. I do not want to read about how your EM1 was stolen...
Old Jul 21, 2008 | 11:20 AM
westonreed's Avatar
New User
Default Re: Need help installing Viper Alarm/Remote Start system! (Player 2)
Player 2, I asked a simple question. If you don't have an answer, then don't comment. I am new to this forum and I apologize if i posted this in the wrong section, but I'm pretty sure that this one time won't cause any harm. You should probably learn how to handle yourself a little better in situations like these. There is no reason to be that rude, when I did nothing to you.
Old Jul 21, 2008 | 11:22 AM
westonreed's Avatar
New User
thanks for the help addiction2bass! Thats what i needed!
Old Jul 21, 2008 | 11:29 AM
o ya if its a manual car then i would HIGHLY SUGEST to NOT wire up the starter wire!!!!!!! you can wire up a starter kill but to tell you the truth a starter kill on a manual car is just stupid.LOL push starting a manual is to easy.LOL
by not hooking up the starter wire on the alarm system you would need to get into the car, start the car with the key then hold the brake pedal down and hit the remote start button on the alarms remote control. that will put the alarm system into STOP & GO FEATURE... which will let you remove the keys from the car and will keep the motor runing for ruffly 10-20mins or your set time to run. its a whole lot safer than hooking up the starter wire and posibly leaning against something with your keys in your pocket and also leaving the car in gear... if it trys to start it wont start BUT the torque from the starter will make the car JUMP forwards or backwards ruffly 5-10ft depending on the alarms crank time!
NOT GOOD... i myself hooked mine up fully BUT i was very diligent to always leave the car in nuetral. but even if your 99% sure you left it in nuetral theres always that 1%chance you left it in gear and it jumped forwards, either into a tree, parked car, off jackstands with you under the car, or just jump forwards into some people or kids. definatly not safe.
tho they do have manual safe remote starter systems now! that you must go thru a exact procedure to leave the car every time or your remote starter wont start by remote. now those are safe for manual cars!
djslim23
Audio / Security / Video
Dec 29, 2013 10:47 PM
2gnarly
Feb 14, 2009 09:31 AM
westonreed
Jul 24, 2008 08:44 PM
IOSUA
Oct 8, 2007 02:19 PM
monsoon
Jul 21, 2003 09:09 AM
