13" rim clearance on a stock 2000 Civic CX?
Old Jul 21, 2008 | 12:44 AM
JDM Approved's Avatar
Default 13" rim clearance on a stock 2000 Civic CX?
Will 13" rims fit on a lowered 2000 Civic EK hatch with stock brake setup?
Thanks guys!
Old Jul 21, 2008 | 06:18 AM
NOFX's Avatar
H-T White Ops
Offset, center bore, wheel size, spoke design.
They might fit and they might not.
Old Jul 21, 2008 | 07:29 AM
94EG8's Avatar
Seagull Management
Default Re: 13" rim clearance on a stock 2000 Civic CX? (JDM Approved)
If it helps any my mother has a '96 CX hatch that came from the factory with 13" steelies. I've also tried my 13" alloys on it just to see what they looked like (13" mangels 5 spoke) clearance is at a minimum, theres about 1/4 inch between the wheek and the caliper, about an 1/8 where the stick on weights are. I'm not sure if honda ever upgraded the brakes on the 6th gen CX through the years, NOFX probably knows though, if not then they will probably fit. If they did upgrade the brakes then almost definately not.
Old Jul 21, 2008 | 01:53 PM
NOFX's Avatar
H-T White Ops
Default Re: 13" rim clearance on a stock 2000 Civic CX? (94EG8)
All '96-'00 Civics in the US save for the EX and Si had the smaller front brakes.
I would expect them to fit, but they might not.
J_Marc
Jul 6, 2007 11:36 PM
lv6l
Dec 12, 2005 10:14 AM
jdmjeff
Oct 27, 2005 05:55 AM
mrtrex
May 4, 2004 03:10 PM
oMek
Mar 27, 2004 09:22 PM
