can DOHC axles fit on cx civic
94 civic cx hatch. i'm planning to put b16 or b18 motor in.(which do you guys think works better for my car). i want to know can a DOHC axle fit on the hub of the cx civic. i dont know is the teeth the same is what i'm asking. thanks.
Re: can DOHC axles fit on cx civic (lv6l)
what year is your civic? Because depending on the year, you may have to change out the hub? I have come across this problem before...
Re: can DOHC axles fit on cx civic (black99ek)
Originally Posted by black99ek
ooops never mind, If your hatch was an SI they would fit. I am positive that they wont on the cx......
Re: can DOHC axles fit on cx civic (junkyard_turbO)
jesus, have any of u guys actually read the question and tried what he is REALLY asking? *edit* except for wob
i swapped a JDM b16 in my 93 cx hatch and used the 94+ teg axels on the stock hubs NO PROBLEM. and he doesnt want to use them for the d-series engine, he wants to do a swap.
just make sure if ur car is ABS to get the ABS axles and if not to get the non-abs ones
good luck
good luck
* B A N N E D *
1 Post
Re: can DOHC axles fit on cx civic (CRXified)
what you may be refering to is the old CRX HF, which may or may not have smaller than the 32mm axle splines.
Yes, 92-00 civics and 94-01 Integras all have the same spline input on the hubs, your fine. Only thing would be if you had like a JDM version of a Type-R motor, as they use bigger axles. Your DOHC axles will go into your stock hubs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified »</TD></TR><TR><TD CLASS="quote">jesus, have any of u guys actually read the question and tried what he is REALLY asking? *edit* except for wob
lol thanks for the plug
civicracer1993
12-02-2002 06:13 PM
