2000boostedex's 94 gsr build thread
Old Jul 20, 2008 | 08:21 PM
2000BoostedEX's Avatar
Default 2000boostedex's 94 gsr build thread
Well I figured I will try and keep a thread updated on the build of my teg which is going into its third makeover I believe.. I bought it a 500hp pump gas beast and then from there I got it to make 655hp with the help of T1. Pics from then are here
and then I pulled that motor after some probs and put in a stock gsr with a turbo kit and was making 316hp with a t1 tune at that time and she looked like this
and now its going on to this and how it sits right now.
I am looking to shave the bay this time around, delete the abs, a wire tuck of course and maybe tuck the brake lines but I wont be getting rid of my heat The power plant will be a b18c with ib spec 12.5:1 pistons and ib spec rods, an itr head with rs machine cams and some other goodies I am sure u will see in pics.. I am going to try out some twm itb's on it and I hope I can get them to work out ok for me. i also have picked up some 15" bronze volk ce28's for the car as well.. Anywho onto progress.
Day 1
Well i finished up the tuck on my eg which is here
and then decided to finally start up on my teg that has been sitting for over 6 months as I gathered parts for its next build.. Today I figured I would start on the motor though so I went ahead and got the old piston rings off the pistons and cleaned them up a little and also fitted the new rings to them after filing them to specs. I went ahead and set the new crank in position and about to start plastigaging everything and then the gf called and I had to go eat anywho here are some pics of today and some pics of the parts going on it.. Enjoy and I will try to keep this thread updated
wiring harness stuff
alot of **** just chilling in the hatch of the teg
jdm itr cluster
pulled all that **** out and sort it a bit for a pic
has my new clutch line and all that good stuff in there and my brake line was in the back seat but I just remembered it was there lol..
the itbs just hanging out
itr tranny with gearspeed carbon coated synchros and quaife (you can also spot the ati super damper in this pic)
the block
the pistons and rods all freshly ringed but waiting for a ring compressor to be put in
where i ended for the day
the nardi deep corn wheel
hardrace a arms and bushings for the whole car
misc itb junk
the head being neglected on the ground
and one of the new wheels going on
well thats it for today and look forward to progress.. I hope
Old Jul 21, 2008 | 09:15 PM
99SlammedCivic's Avatar
Snipper Snapper
Wow... Looks like a bunch of junk
Old Aug 4, 2008 | 08:55 PM
Default Re: (99SlammedCivic)
well finally got around to doing something on the car lol since the crank thing is still bothering me. Anywho some progress today was all on the brake system and getting lines and the abs out. Also got the clutch lines out and most of the headlight harnesses out of the bay. Fenders are almost off just got to put that one bolt out below the sideskirts but I was tired by that point. Here is a pic of where I left off for the day..
Old Aug 7, 2008 | 05:19 PM
Default Re: (2000BoostedEX)
Today I got the axles back out, got all the abs bs out, and the traction bar.. got the fenders off and side skirts as well so the tuck on the front will be done soon as well as starting on shaving the bay and tucking the brake lines.. Here are some pics of the day ended here and alot of stuff soaking with PURPLE POWER
Old Aug 9, 2008 | 08:17 PM
Got some more work done today. Went ahead and pulled the dash and the hvac stuff and started to work on the harnesses. I had to reloom the whole p/s side harness to get all the abs stuff out of it because I am no longer using abs. Also got most of the srs wiring out but the brain is still there until i get a torx bit to get it out but I will have that next week. Got the driver side harness done as well just had a little work to do on that side so it didnt take long. Should be starting on shaving the bay here soon, I can't wait Here are some progress pics
all the abs bs
fuse box now inside hanging out for the time being
cluster[freak]imus
Will be working some more on it tomorrow so keep looking for updates.
Old Aug 10, 2008 | 05:04 PM
Few more things were done today. I retaped and loomed the whole passenger side headlight harness and driver side harnesses so those are both done now. Also got the srs brain out and the brackets that go along with it. Removed a few brackets from the engine bay since I got the new spot weld drill bit I started to remove the subframe to start getting it cleaned up and painted but of course one of the tie rod ball joints wont come off so I will have to try that again another day. Oh well here are some pics of today
The engine harness connectors
where the brain used to reside
I only got a decent pic of the p/s headlight harness I forgot about the d/s
all the abs stuff finally out completely
where the brackets once were
and how I left it for the day
Old Aug 14, 2008 | 11:51 AM
junkyard racer's Avatar
Looking good man! What do you think of those hardrace control arms?
Old Aug 14, 2008 | 06:05 PM
Default Re: (junkyard racer)
i like em.. they are really nice and quality looks good. they are replacing my skunk2's that i have now because they slip all the time..
Mehofaca1
May 20, 2011 05:33 PM
SanJose408
Mar 26, 2008 06:22 PM
georgekobe8
Aug 28, 2007 12:55 PM
ping83
Jun 19, 2006 07:53 AM
Brewer
Mar 10, 2004 02:12 PM
