Pinging/Detenation, B16a2 searched
Old Jul 20, 2008 | 07:46 PM
Civichatch2k's Avatar
Default Pinging/Detenation, B16a2 searched
Hey guys here is the problem.
While driving my car, the motor is detenating between 3-4 RPM's. I can avoid the detenation if I keep the throttle at a minimum. However when I push the pedal closer to the floor/ opening up the throttle if the engine is in this RPM range i hear nothing but detenation.
Too much timing? The head is milled .020 and other then that it is a stock motor besides cams, comptech intake, skunk manifold, dc header.
I just dont know what to do to stop the problem. I am running a chipped ECU and I don't know what the specific program it is but I was told that it was designed for a 1.8liter. I think it is a timing issue, but just not for sure and not sure what to put the timing at to find out.
So Let me know what i need to provide if I need to give any other info.
Thanks!
Old Jul 21, 2008 | 10:13 AM
inspyral's Avatar
What octane fuel are you running? Too low of an octane rating will cause detonation if the engine is spec'd for 91/93. Is your base timing set to stock? The fact that you're unsure of the bin/ROM in the ECU is also worrisome. You could be running on one of those generic "Mugen/JUN/Spoon N1 Type R" programs designed to run on higher octane Japanese fuel with aggressive timing maps. If your setup is near stock, your best bet would be to run a stock B16 ECU, or have a stock B16 bin burned onto a an EEPROM and swap out your chip.
Old Jul 21, 2008 | 12:05 PM
Default Re: (inspyral)
Well I am running 89 but just because of the price. I had been running 91 but that didn't change anything.
I know some people that can burn stock maps, I will have to get in touch with them and have them burn one for me.
I have the stock ECU but I am not going to use it because it throws a check light and then gas mileage goes to ****.
I will have to get the chipped burned with the b16 program.
Thanks for the thoughts!
Old Jul 21, 2008 | 12:35 PM
hotrod99's Avatar
Default Re: (Civichatch2k)
what its throwing a check engine light for?
Old Jul 21, 2008 | 02:24 PM
King V's Avatar
Default Re: Pinging/Detenation, B16a2 searched (Civichatch2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civichatch2k &raquo;</TD></TR><TR><TD CLASS="quote"> The head is milled .020
Thanks!</TD></TR></TABLE>
Are your cams degreed properly? Milling the head retards the cams.
Old Jul 21, 2008 | 09:10 PM
2nd o2 and knock sensor.
yes they are correct.
Old Jul 22, 2008 | 08:18 AM
mtber's Avatar
1. Check to make sure timing belt is all lined up properly with cam gears at TDC
2. Check distributor timing to make sure it is at a factory 16.5 deg btdc
Bigjussin
Oct 21, 2004 04:31 PM
4ornia
Mar 27, 2004 10:12 AM
X2BOARD
Mar 16, 2004 04:00 AM
Dc5-Power
Jan 22, 2003 05:32 PM
