IACV problem, 96 civic dx... no code w obd2 LS ecu but code 14 with obd1 LS ecu
turn your idle screw on the front of the throttle body till you get your desired idle.
http://www.ff-squad.com/tech/tb/tb.nofitv.jpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxh00 »</TD></TR><TR><TD CLASS="quote">turn your idle screw on the front of the throttle body till you get your desired idle.
http://www.ff-squad.com/tech/tb/tb.nofitv.jpg</TD></TR></TABLE>
ive already done that. it still goes low then dies, and throws code 14, but idles fine if reset when engine is warm.
tried the conversion harness and ecu in my integra and it works fine, still lost on this
Cimburke23
Jul 20, 2008 05:13 PM
