CAR SHUTS OFF PLEASE HELP!
Old Jul 20, 2008 | 04:43 PM
TattoonistInk's Avatar
Default CAR SHUTS OFF PLEASE HELP!
it started about a month ago....i was driving and my car just bogs down and shuts off....i try to crank it..it just keeps turning over...i wait 5 minutes and it starts right back up....i put on a new distributo.....new main relay....new fuel pump...and new fuel filter....still nothing....i have a 92 honda civic hatchback with a JDM D15b VTEC....when i found my ecu...it says D16A on it....
the ecu reads...
37820-P91-000
736-701173
could this be my problem....ive had people tell me its the ignitor....ignition module....ecu......water in my gas tank..lol....
someone please help me..i dont know that much about these engines....neither does anyone around my town...HELP PLEASE!!!
it cranks....idles/drives for 10-15 minutes...then shuts off....it wont start right up...just turns over......if u wait 5 minutes...it will crank up fine then run for another 10-15 minutes.....i hear the 3 clicks of the main relay...and hear the fuel pump whril in the tank.....HHHHEEELLLLLLPPPPPP! please thanks guys
Old Jul 20, 2008 | 06:45 PM
SOHC SPEED's Avatar
Default Re: CAR SHUTS OFF PLEASE HELP! (TattoonistInk)
it sounds to me like you have a distributor problem(i know you just replaced it) try checking if you spark next time this problem happens also do you get a check engine light when thi happens? im not sure about the ecu. has your car always had this ecu? also check for loose conections and loose grounds
Old Jul 20, 2008 | 07:26 PM
tonylor89's Avatar
Default Re: CAR SHUTS OFF PLEASE HELP! (SOHC SPEED)
dude change he ecu......that ecu is for a 87-89 integra....change it to a p28 which ish good for single head vtecs
Old Jul 20, 2008 | 08:17 PM
crxcess's Avatar
Default Re: CAR SHUTS OFF PLEASE HELP! (tonylor89)
did you buy a complete distributor, or did you have to move parts over from your old one?
Heize312
Honda Civic (2001 - 2005)
Dec 1, 2018 04:10 PM
91_Project
Jul 30, 2014 11:49 AM
buckwheat1988
May 30, 2012 07:28 PM
gone postal
10
Jul 22, 2008 10:24 AM
LsVtakYO
Jan 18, 2006 01:15 PM
