Help! I need A new main relay for my 90 crxsi !
my car will sometimes start and then die almost immedietely after, especialy if the weather is hot. I finally figured out the problem, its the main relay. If you have the same problem then thats most likley what it is. Now that I know what the problem is and located the main relay I need to know where can I pick One Up and IF anyone Knows. How much? thanks A lot. any help apreciated!
its called a multi-purpose relay in their books
gp sorsen or wells number is
41-5062
$57.99 autozone
cheapest ive found
if you go in there and ask for main relay you will get something else
41-5062
$57.99 autozone
cheapest ive found
True, it is a common problem with the CRX. Here is a write up that many people online use to fix the main relay.
http://www.markl.f9.co.uk/howto/elec...main-relay.htm
Soldering skills? There is no such thing, soldering's easy! But I know what you meant. I think everyone drops some solder on their shoes, shorts, or hands (OUCH) at least once...by the way, thanks for that link, Mood...should prove to be very helpful.
Alex
Alex
Ive got a relay for you if you want from my car I parted out and junked... ill sell it to you for 10 bucks plus 5 shiping.. it works perfect.. no problems.. email me at - Skunk2ner@aol.com
Noor Cabir
Honda Civic (2001 - 2005)
Jul 5, 2016 01:37 PM
rocaveli
33
Jul 13, 2005 03:16 PM
EF9 JAMS!!!
Mar 6, 2005 02:10 PM
